Hi, it is caused by a blown 20 amp fuse in series with the Primary door switch.
CORRECTION: Most often the first attempt is to change, or adjust, the primary door switch, but components (20 amp fuse, 15 amp fuse and cavity thermostat) in series with the primary door switch are the culprit. Check and replace as necessary the 20 amp fuse, the 15 amp fuse or the cavity thermostat.
