Filters clean? Fan running? No clogs in the exhaust?
On the one hand, you want the disagreeable stuff out of the kitchen - on the other hand, you want to keep your heated or cooled home air to stay inside.
Hi. If this is a ALL electric cooker then you can do the job yourself. If partly gas then you MUST have it done by a ALL GAS qualified engineer.
Its a fairly easy job but you will have to unscrew several screws on on the underside of the front panel and also on the rear of the appliance. If you would like assistance then please phone me on 01733 307019
Yes, the handle, doors and knobs can all be removed, in fact (If I remember correctly) the unit is delivered with at least the handle/rail at the top not fitted. I would still suggest that you visit the supplier with a tape measure and suggest that if they want sell you a unit, they reassure you by showing you a packaged unit, or demonstrate the removal of the handle.
There are two elements on the grill, left and right. One has failed and needs replacing. Can't tell you how, we haven't got that far, but we bought replacements from e-Bay £9.99 each + £2.50 P+P. Official suppliers charge £21+.
We have the same problem on a Rangemaster Toledo 110. It is not a fuse.
The 'Hot' light still comes on because that is a different (parallel) circuit.
Examination by a competent electrician has found that the soldering for the wires that power the warming metal strip under the glass is faulty. You will have to ask for a replacement part.
There may be a design flaw, so you might want to enquire about the professional all gas burner top and just use the griddle as a warming plate over the second wok burner.
The left hand oven needs a new flame failure device fitted , it is a normal oven not for slow cooking . This repair can only be carried out safely by a registered Gas Safe engineer . Visit WWW.gasSafeRegister.co.uk or ring freephone 0800 408 5500 to find one in your area.
