Acer Aspire 5100 Notebook Logo
Posted on Apr 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get the acer erecovery management page to give me the option of making a DVD recovery disk
Anonymous
Level 2:
Scholar:
  • Expert 75 Answers
  • Posted on Apr 26, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
75
Questions
0
Helped
44934
Points
183
Hi!
You can try the following steps:
1. Click on "Start" and then click on "Control Panel."
2. Double-click on "Backup and Restore Center" if you are using Windows Vista. If you are using Windows 7, click on "System and Maintenance" and then click on "Backup and Restore."
3. Click on the "Create a system repair disc" button in the pane on the left-hand side of the window. A new dialog box will open.
4. Insert a blank DVD (or CD if you do not have a DVD, but you may need to use several CDs, so a DVD is better).
5. Click on the drop-down menu in the dialog box and select the DVD that you inserted into your DVD drive.
6. Click on "Create disc." Wait for the green progress bar to fill while the disc is written. When this is done, a new box will open with a message telling you how to label the disc.
7. Label the disc according to the name in this message and then click on the "Close" button to close the box.
8.
Click on "OK" to close the next box and then close the Control Panel.
9. Remove the recovery disc from your computer and put it somewhere safe until you need it.
Hope this helps. Thanks.
2helpful
3answers
Ive lost a recovery disk and now i cant reinstall,is there any way i can download off the net and make new recovery disks?
Two seperate issues. You can order new disks on ebay for example but if your product key is unreadable you need to purchase a new key.
See this link to buy - http://www.amazon.co.uk/Microsoft-Windows-Home-Premium-inkl/dp/B008OT79T4/ref=sr_1_2?ie=UTF8&qid=1426423337&sr=8-2&keywords=windows+7+coa
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Erecovery management for acer aspire one without disk drive wont run
Ask acer for this problem, when you buy a laptop you need to make recovery discs, you prolly did not do that. So now it asks for recovery files on the dvd disc.
If it has no dvd drive you should have made them on a usb drive.
If acer cant help you with that, reinstall windows thats the only option.
Partitions hidden can be removed but then there is no way to restore the pc to factorydefaults anymore.
When you decide to reinstall windows, you will see 3 partitions, remove them all, then make 1 partition click next and it will make a little partition for system files. the rest is used for windows, untill u partition the rest, like a d: e: drive.
Hi there, I have an acer travelmate 4230 wlmi laptop, recently my laptop was struck with viruses which corrupted lot of my applications including acer erecovery because of which I ran the acer erecovery...
Instead of going with a backup and recovery try the destructive recovery option which will wipe off the entire harddrive and take the system to day one settings.
3helpful
2answers
Recovery disc
To create an Acer recovery Disk from the computer follow the below mentioned steps:
Click Start Menu> All Programs> Acer erecovery management> Under it select the option to create Recovery Disk
11helpful
3answers
Restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
2answers
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
1helpful
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
your Acer system.
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
How can do i clear my hard drive and reinstall windows
You can launch Acer eRecovery Management in a number of ways:
By pressing the hotkey <Alt> + <F10> during the boot-up process, or at any
time when you are running Microsoft® Windows®.
This will open the Acer eRecovery Management main page.
Password
Acer eRecovery Management requires a password to activate. The default
password is six zeros (0s).
Note: If an incorrect password is entered three times, Acer
eRecovery Management closes and returns to Windows®
automatically.
System recovery
Step 1: Click on “Recovery actions”.
Step 2: You are presented with a list of available options
CHOOSE-->Recover system from CD/DVD backup
If you choose to restore from an image on an optical disk, the BIOS will be
changed to boot from the optical drive. If no backup disk is found, you are
prompted to insert the disk.
Reinstall
IF THOSE DISKS DONT WORK , YOU CAN ALWAYS RESTORE TO FACTORY SPEC FROM THE HIDDEN PARTITION ON YOUR HARDDRIVE.
Hope this helps you out .. Regards
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
