Question about KLH R5100 Receiver
My sound doesn't work with the DVD fuction. It works on the Tuner, the VHS1 but not DVD. Do I need to connect the S-Video cable or what else should I try?
    Brigadier General:
  • 8,546 Answers
S-video would be a better choice than (yellow) composite video but it won't help the sound.
Not knowing anything about the DVD player and how you have it wired we can only guess what is wrong with IT or the connection to the KLH.
Have you looked at the manuals for the DVD and the KLH? You don't just hook it up and run with it. Digital Audio must be assigned, for example, and other stuff.
Posted on Apr 25, 2011
SOURCE:
I have a Toshiba 32a33 TV, I have tried to program channels into the TV but it doesn't work. I tried to do it both manually and using the automatic channel tuner but it doesn't work. What should I...
Either the tuner or the video IF stage circuit of your TV is faulty. Tuner has no repair, can be replaced as a unit. If the fault is with video IF stage, it can be repaired. But, both the work is skilled one. You must have through knowledge in electronics, and work experience to do this work.
Jul 21, 2012 | Televison & Video
My flipdown DVD player in the car is having tracking trouble-get a series of horizontal lines that jump around screen, happens on both DVD and vhannel tuner. Thanks
it sounds like you reception is getting crossed on the video input.
or you video input cable has worked it's self loose not getting a good connection. i would check that to start out with.
Aug 14, 2008 | Audiovox Televison & Video
How do I connect a dvd player with surround sound?
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
Jun 24, 2011 | NEC 42VP4 42 in. EDTV-Ready Plasma...
RX-V461 Yahama Receiver is hooked up to TV with optical THX cable but can't get sound. Tuner on receiver plays and all speakers work perfectly for radio listening.
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Feb 10, 2011 | Yamaha RX-V461 AV Receiver
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Screen just went black
Think your set tuner is bogus. The other tuner that you used should work, but if it is not a cable tuner configured to your system it will not work either via the rf outputs or the audio video outputs. If that cable box works with another set then you have a real head scratcher on your hands.
Mar 24, 2017 | Sanyo AVM-2756 27" TV
Toshiba VCR/DVD Recorder Combo - Problems connecting it to system
I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
May 21, 2008 | Televison & Video
No input from cable connection
Sounds likely you have a bad tuner. If you have a cable box with your cable service and it is upgraded for video and audio rca jacks output you can run red white and yellow wires to tv input where the DVD is connected or additional jacks if available. This bypasses the tuner
Jan 01, 2008 | Televison & Video
Hp z558
This sounds like a poor put together pc. If the DVD drive does not eject then either the dvd is faulty or the IDE cable and/or IDE1 connector on motherboard is not installed, try ejecting through my computer(right click on drive then Eject), if this works the button is faulty. The same goes for the TV Tuner card, again possibly a corrupt or non installed driver, try re installing mother board drivers and card drivers. This really needs to be returned as the pc is not fit for it's use.
Feb 19, 2007 | HP z558 (EG652AA) PC Desktop
No picture or sound - think the tuner is bad
You may either have a bad tuner in your TV (not unusual for Sony's) or a broken connection near the tuner on the flimsy circuit boards they're using on this model. The tuner requires about 30 volts DC to work, and this may not be reaching the tuner due to a crack in the board connection. You probably have several A/V inputs that can be used for cable video and DVD video and your owners manual should explain how to connect them clearly. The outputs of those units go into the inputs of the TV set. It's That Simple!
Jan 24, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
KLH R5100 Receiver Logo
244 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
