Olympus W-10 Digital Voice Recorder Logo
Posted on Apr 25, 2011
I have a Bell Office 600d digital voice recorder and Windows 7. I want to copy the recordings onto my PC, but when i try and open one of the files it says that the shortcut has been removed or deleted (i didn't do any such thing), and i can't open or copy the recording, but it works fine on the voice recorder itself. Help?
  • Anonymous Mar 28, 2014
    Need to change the date
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
700
Points
6
Hi Alana,
There is in all liklihood nothing wrong with your digital voice recorder. It was never designed to work with Windows 7 (any version). Try loading the voice files onto a PC with any one of the following operating systems:
Windows VISTA; Windows XP (Professional or Home); Windows Me; Windows 2000 (Professional); Windows 98 (Second Edition). It should function quite normally and download, so that you re-use the memory on your recorder.
Software bell office 600d voice recorder
I have Windows Xp. I have Bell Office 800D. Which software do I download.
Coby Voice Recorder CXR-190 wont work with MAC - any solutions?
Coby only claims the CXR-190 is compatible with Windows Vista/XP/2000. I'm afraid your best solution is to use a Mac-compatible voice recorder.
If you need the recordings currently on the machine, copy them onto a PC and then transfer them to your Mac.
I have the olympus vn-2100pc and windows 7 how do I transfer my files onto my pc?
The VN-2100PC is not compatible with 64 bit O/S neither xp or vista or 7....sorry.
Available software downloads can be got at www.olympusamerica.com
6helpful
2answers
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
1helpful
JNC usb 350 digital voice recorder
i have jnc usb-350;
i can not installing drive and software.
i can not capture data from voice recorder to computer.
2answers
Can't copy files from Sony ICD-SX57 Recorder to PC using Digital Voice Editor
I have the same issue with this recorder and Vista. According to Sony, the new version should be available for download "sometime this month" so I'm holding my breath. There is a way to get your files onto your computer, but it is pretty annoying when you have a bunch. But it works, so here it is. Select the specific recording that you want to save, then click the "email" button. If you use Outlook like me, an email window will open up and your selected file will be attached. YOu can then save it from the outlook email window without even actually sending it. Once it is saved on your computer, the DVE commands that allow you to convert the file do work, so have a ball! This sure does suck, no? Mark
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
