Question about LG LHD459EL Dehumidifier
My LG Dehumidifier's fan does not seem to be operating. The filter is clean, the motor runs, but no air circulates through the machine and no water collects in the bucket. I bought it on 10/22/2006.
  • LG Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
SOURCE:
The motor is still running fine, but the dehumidifier is no longer extracting water from the air and the water container is not filling.
John, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 19, 2011 | Haier 45-Pint Dehumidifier
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Jul 03, 2011 | Dehumidifiers
Machine runs, but no water is coming out into the bucket
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | LG LHD459EL Dehumidifier
My Goldstar Dehumidifier is not collecting water. There is no air coming out the back. I have cleaned the filter.
Hi, Sounds like the fan quit....could be the board or the fan motor ...check for power at the motor...
heatman101
May 21, 2011 | Goldstar Dehumidifiers
Dear Sir , the dehumidifier is running the motor is running, but not sending out any water. I have cleaned the filter.n Any recommendations?
Is it only the fan motor running that you hear? Or is it the compressor motor and the fan motor in combination?
If it's just the fan motor, it running to circulate the air, in an effort to sense humidity in the air, above the level you have the humidifier set on. Speaking of which, you may have the level set higher than what the humidity is in the house and the unit is just maintaining it. 50 to 60% is high, as opposed to 35%, which is what most folks want to maintain in the hot, humid, summer months.
If you want to test the unit, place in the bathroom, turn a hot shower ON, turn the humidifier ON and set it for 45% or minimum if your unit does not have a LED readout screen. Do Not turn the bathroom exhaust fan ON. As you leave the bathroom, close the door and don't return for 20 minutes. When you do, turn the shower OFF and check the humidifiers water collection bucket. If you see any water, the unit is working as it should. If you don't see any water, it's time to replace that unit. I say that because, at best, the parts and labor to repair the unit would be equal to or almost equal to, the price of a new dehumidifier.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks
May 20, 2011 | Fedders A7DH45B2A Dehumidifier
The dehumidifier runs, cycles on and off, but there is almost no water in the receptacle. I haven't had to empty it since it started cycling on & off this season. I usually have to empty it at...
You may have the humidity setting to high. Try lowering it to 45%. Or if yours doesn't have an LED Screen, set it for minimum. Also, check and clean the air intake filter, if you haven't already. Keep in mind, most dehumidifiers have a fan that may seem to run constantly, but the compressor doesn't turn ON. The fan is circulating air, in a effort to detect humidity levels that are higher than what you have the humidity removal set on.
Hope this helped you.
May 10, 2011 | LG LHD45EL Dehumidifier
The fan is on but no water is collecting
Check to see if compressor is operating.
Apr 08, 2010 | Haier 45-Pint Dehumidifier
Water condenses on top of dehumidifier
Your unit has a sealed system leak. The sealed system is warrantied for five years. Check your owners manual for this info. You will need your receipt and to call an authorized LG warranty dealer to exchange it.
Oct 06, 2009 | LG LHD45EL Dehumidifier
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
Running but not collecting water...
Dehumidifiers have only a few components, and operate on the same principle as a refrigerator, freezer, or air-conditioner.
Components Residential dehumidifiers have a cooling system made up of these primary components:
  • The compressor is the quiet motor (engine) of the cooling system. It's the black, football-size component at the bottom of your dehumidifier. The compressor runs as long as the dehumidifier humidistat (the humidity-sensor) calls for a reduction in the humidity.
  • The condenser is a series of finned tubes, similar to a radiator. It's usually near the circulating fan.
  • The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
  • The circulating fan circulates the air over the evaporator and condenser coils.
Principle When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Jul 29, 2008 | Maytag M7DH65B2A Dehumidifier
LG LHD459EL Dehumidifier Logo
194 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
