Hotpoint Ultima WF865 Front Load Washer Logo
A
Anonymous Posted on Apr 25, 2011
It keeps coming up h20 on lcd screen - Hotpoint Ultima WF865 Front Load Washer
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Apr 25, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1025580
Points
20216
(Quote)
Error code H20
If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.
If your machine IS in demo mode come back to me and I will tell you how to get back to normal mode - it's too long to put in this solution ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Testimonial: "got the washing machine working thanx but now cant seem 2 get the door open"
  • Anonymous Jun 27, 2012
    i have done what u said but it still says h20 but it is washing but water is licking at the bottom could it mean it is blocked ty
I purchased Haier HLP23E washing machine 2 years ago. I only used it twice. Decided to use it again: however my problem is that I can't get the H20 to flow into the tub at all. Can you help me?
Check to be sure water is cut on and there is actually water coming from hoses. Make sure hot and cold hoses aren’t switch at Machine. Make sure valve and hose screens are free from debris.
1helpful
My H20 x5 steam mop keeps tripping the electric I have changed the fuse but this still keeps happening please advise?
Please stop using the mop before you have the thing catch on fire, or even your house/apartment.
What may have happened is the steam/water may have gotten in to the motor some how and is shorting it out.
Jul 11, 2016 • H20 x 5 Mop
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
1helpful
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Does not complete cycle comes up with -H20 on screen
Hi.
Fault code H20 is indicating that the washer is not filling correctly, check tap/s hoses, and inlet valves for water supply.
Please rate my solution.
Thanks.
1helpful
Blue strips on sony DSC-h20 while looking on lights
its only visible on display. Once you take the snap it will not be visible in the shot. Switch to Inteligent mode, it will remove the blue strips on display.
Cold h20 not going into tub, and LF light comes on when tub empty
Is the cold water valve on if so your water valve screen is probably clogged . disconnect your hoses from the machine and clean out the sediment. LF is long fill the rinse is usually cold water .that you do not have. good luck let me know what you find.
2answers
H20
According to the Hotpoint error code list H20 indicates to check taps and pressure of incoming water..
So make sure you have adequate pressure of water at the valves, low hot water pressure can cause problems..
Also what I would do would be to check the filter located in the sump hose at the rear of the m/c,\this can leade to a sticking water level s/w..
Hope this helps.
Plz leave feedback.
Thanks.
Hotpoint Ultimasimply flashes H20.
witch one of theses are your washing machine?
lcd evo01
lcd evo02
or the V4
please let me know so i can get you the right term for the code.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
