Health & Beauty Logo
Posted on Apr 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I lock and unlock the vsi joystick on a rascal 320 powerchair. The manual says to push horn twice within 10 seconds to unlock. Is the locking procedure the same?
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Apr 25, 2011
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288563
Points
1801
Right to left 'chase' SHARK is in Lock mode. To unlock SHARK, press the Horn
button twice within 10 seconds. To lock SHARK, press the Power button for two
seconds then release. Hope this helps
tip
VSI joystick constantly flashing
You may have mistakenly locked your joystick. Here is a tip on how to lock and unlock it.<br /> <br /><b> <p>LOCKING/UNLOCKING THE VSI<br /></b> <p>The VSI has a feature that enables you to lock your power chair to prevent<br /> <p>unauthorized use.<br /><b> <p>To lock the VSI:<br /></b> <p>1. With the VSI powered on, press and hold the on/off key. After one (1)<br /> <p>second, the VSI should beep.<br /> <p>2. Release the on/off key.<br /> <p>3. Push the joystick to the full forward position until the VSI beeps.<br /> <p>4. Pull the joystick to the full rearward position until the VSI beeps.<br /> <p>5. Release the joystick. There should be a long beep.<br /> <p>6. The VSI is now locked.<br /><b> <p>To unlock the VSI:<br /></b> <p>1. Press the on/off key and power on the VSI. The maximum speed/profile<br /> indicator should ripple side to side.<br /> <br /> Good Luck<br /> <br /> mimobility<br />
on May 05, 2011 • Health & Beauty
tip
UnLocking Sleep and Lock Modes for Pride and Invacare power chairs
<p><b><span>Pride Joysticks and others that use VSI joysticks</SPAN></B><br><p><b><span>SLEEP MODE</SPAN></B><br><p><span>Your VSI controller has a sleep mode feature. Sleep mode is a built-in circuit </SPAN><span>that automatically shuts off the main power if the joystick is not moved </SPAN><span>in any direction for a period of time predetermined by controller program.</SPAN><br><p><span><b>The battery condition meter lights on the keypad indicate sleep mode by </b></SPAN><span><b>blinking once every five seconds.</b> To restore power and continue, push the </SPAN><span>on/off key twice.</SPAN><br><p><span> </SPAN><br><p><b><span>Lock Mode</SPAN></B><br><p><b><span>To unlock the VSI:</SPAN></B><br><p><span>1. Press the on/off key and power on the VSI. <b>The maximum speed/profile </b></SPAN><span><b>indicator should ripple side to side</b>.</SPAN><br><p><span>2. Push the joystick to the full forward position until the VSI beeps.</SPAN><br><p><span>3. Pull the joystick to the full rearward position until the VSI beeps.</SPAN><br><p><span>4. Release the joystick. There should be a long beep.</SPAN><br><p><span>5. The VSI is now unlocked.</SPAN><br><p><span> </SPAN><br><p><i><span>Invacare and others that use SPJ+ joysticks</SPAN></I><br><p><i><span></SPAN></I><i><span>FOR SPJ+ Joysticks</SPAN></I><br><p><i><span><b>Lock Mode will be indicated by all LEDs</b></SPAN></I><br><p><i><span><b>flashing briefly and the information gauge</b></SPAN></I><br><p><i><span><b>LEDs chasing slowly from right to left</b>. If</SPAN></I><br><p><i><span>this occurs, press the horn button two times</SPAN></I><br><p><i><span>within ten seconds to unlock the joystick.</SPAN></I><span></SPAN>
on Nov 16, 2010 • Health & Beauty
1helpful
Unlock the controller
Locking/Unlocking the VSI
lock your powericon1.png chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speedicon1.png/profile indicator should ripple up and down.
When i push power button on lights blink constantly, wont move
For future reference, here is the is a procedure for
To lock the VSI:
To unlock the VSI:
2helpful
Can i lock the controls on my jazzy 1121
This is taken from the owner's manual from the 1121 with a VSI controller:
I suggest you print this out and keep it handy.
lock your power chair to prevent unauthorized use.
To lock the VSI:
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
3helpful
Forgot how to unlock power chair
This is the procedure to unlock the controller on a Pride Jazzy:
To lock the VSI:
To unlock the VSI:
1helpful
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Speed lights flash and machine will not run
Hi patriped,
Sometimes we lock our joystick by mistake.
Here is how to unlock it.
If this dosen't fix the problem you may have a bad joystick. Write me back for more info if thats the case.
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
My chair wont move the lite diplay shows 7 lights the joy stick feels like it is out of the sosket
If you have a vsi joystick seven bars means there is a possible joystick trip
a joystick trip is indicated . Make sure the joystick is in the center postion before switching on the VSI.
It may also be locked try this.
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
