HP DeskJet 1280 InkJet Printer Logo
Posted on Apr 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Am hving hp deskjet 1280 printer but after the driver installation when i give print it doesn't print and nothing the message showing me.
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Apr 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
Helped
16182
Points
223
Hi
I think you must check some things like:
- usb cable is good cable and work correctly.
-your computer USB ports works correctly.
-the power is connected to printer and its work and its leds plink.
-you choose the write driver.
Cips
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 30, 2014
Cips
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1179
Points
6
Please make shure that printer is not offline, or other printer to be set default. Also if you press resume printing at the printer for more than 3 sec internal printer test page is coming out, if not check cartriges
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
1helpful
HP 1280 Deskjet is not printing on network
sounds like the computers are not seeing it have the drivers loaded okay,,cartridge contacts may be dirty
1helpful
I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
2helpful
3answers
4helpful
2answers
Error in A3 print
I had the same problem. Didn't find the answer. I removed the HP 1280 driver and installed HP 1220 Driver. It worked. It prints all the sizes perfectly. What is in name if we get the prints on A3 size. whether it is HP 1280 or HP 1220 :)
Ajay
Hp deskjet 1280 unknown a3 paper
Uninstall the HP 1280 driver and install HP 1220 driver. it will print on A3 size.
Ajay
6helpful
Cannot print A3 on HP 1280
go to custom then set your paper size 297x420mm
3helpful
8answers
Problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
Printer not working
sir your system has some error you should check it first and re install the driver
k24674
Grand Canyon Tech
Grand Canyon Tech
