Delfield 406 / 406-CA Refrigerator Logo
Posted on Apr 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a restaurant refrigerator , when I spray water to the refrigerator's compressor and the temperature went down to where I need to be, so I wonder do I have open up and clean the compressor?
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Delfield Master 518 Answers
  • Posted on Jun 25, 2017
Marat Brikov
Delfield Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324327
Points
3123
Slytman
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on Apr 25, 2011
Slytman
Expert
Level 2:
New Friend:
Answers
64
Questions
0
Helped
14219
Points
163
Sounds like the condensor coil needs a good cleaning. The coil is probably under the unit and filled with lint and dust. When you clean this it should help.
Chiller power pack controlled by ranco temp control won't shut down compressor once it reaches set temperature just runs and runs and runs
There are a few potential reasons why your chiller may not be shutting down even when it reaches the set temperature:
  1. Faulty temperature control: If the Ranco temperature control is faulty, it may not be sending the correct signal to shut off the compressor and fan. Try replacing the temperature control to see if this resolves the issue.
  2. Incorrect wiring: Make sure that the compressor and fan motor are wired correctly through the Ranco temperature control. If the wiring is incorrect, the temperature control may not be able to properly control the chiller.
  3. Dirty condenser coil: A dirty condenser coil can cause the chiller to run constantly as it struggles to cool the refrigerant. Check the condenser coil and clean it if necessary.
  4. Low refrigerant charge: If the chiller is low on refrigerant, it may run constantly as it tries to maintain the set temperature. Have a technician check the refrigerant level and add more if necessary.
  5. Faulty compressor: A faulty compressor may continue to run even when the set temperature is reached. Have a technician check the compressor to see if it needs to be repaired or replaced.
I have a ffus2613lp. Yesterday the alarm started going off with the doors closed. The inside temperature raised to room temperature. I pulled it out, cleaned everything, including compressor/coils. ...
Good Afternoon Friend,
I understand the Hi Temperature alarm was going off on your Frigidaire refrigerator, model# FFUS2613LP, and the temperature was room temperature. I also see that you pulled out your appliance and cleaned everything, including the compressor and coils. You turned your refrigerator back on and it froze a cup of water before you went to bed. However, when you woke this morning, your refrigerator was back at room temperature. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it keeps warming to room temperature. Hope this is helpful.
-Best Regards-
WP
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Cant get my GDM 69 to go below 40, seems to cycle fine just won't go any lower even after turning the thermostat knob
Unplug the unit. Clean your condensing coil, the one by the compressor. Nothing fancy, just get a narrow plastic or brass wire brush and follow the lines of the coil fins. If you like, spray in some heavy duty de-greaser like you use around your restaurant and rinse thoroughly.
Broke down today, pajero 2.8 turbo diesel lwb, temperature went from normal straight to high, coolant sprayed all over engine, big hose from radiator to under turbo cooler blew and large hole out, oil was...
with cold engine refill radiator, leave cap off, crank engine if water spurts up out radiator is a head gasket or head fault, these heads are not resurfaceable new head would be required
1helpful
Suddenly showing "HI" in room temp window. Cold then warm air blows out.
"Hi" means your compressor has gone off on a high temperature limit. Basically, your outdoor coil is dirty and needs to be cleaned or your outdoor fan has stopped working. An air conditioner works off a simple principle of removing heat using a low temperature and low pressure refrigerant. Your compressor does what it is called. It changes that low temperature, low pressure refrigerant into a high temperature and high pressure refrigerant. Your outdoor fan blows over that high pressure gas and it blows out hot air. First thing to check is to turn your unit on, and go outside and feel if you have any air blowing out the back. If you don't, you have a bad fan. If you do, you need to clean your coil. Spray some simple green on your outdoor coil and let it sit for about 15 minutes. Then grab a hose and under low water pressure, wash out your coil from top to bottom pointing the hose in a downward direction. You do not want to point the hose straight into the unit. Make sure you disconnect the power and allow it a couple hours to dry before you plug it back in. If it's just a dirty coil, you should be good to go after that!!
2answers
Temperature gets and stays around 40 degrees then back freezes up
Have you checked the fins in the back to make sure that they are clean and not clogged with dust. If you have or you do not have any then your compressor is bad and you are best just throwing it away. If you have fins back there, use a spray bottle with hot water and put a towel under it and just spray and spray and spray until you can see through it with a flash light
Clean the condensor
You can clean the condenser while it is running or you can unplug unit . most of the time you can use a nylon brush to brush off the condenser. If it has not been cleaned in a while you may need some sort of compressed air to blow through it. If units are in restaurant and by fryers or have greasy buildup on them you will need to unplug unit and spray some degreaser on it then rinse with water. It is important to clean the condenser, the part with fins and is located by compressor, because a dirty condenser will shorten the life of the compressor.
Top Delfield Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
