Hard a hard time finding it too. Found an old instruction sheet lying around:
Step 1) Turn the Dimmer On
Step 2a) Press & hold the Dimmer's tap button. LEDs will blink one at a time, from the bottom up to the top. After approximately 8-seconds, the LEDs will start to cylce slowly from top to bottom (setup mode). CONTINUE to hold the tap button and go to step 2b.
Step 2b) Press and hold the "ON" button on the Wireless Controller (MRF-VCTX).
Step 2c) Once the dimmer learns the wireless controller, the LEDs on the dimmer will cycle quickly from top to bottom. Release the dimmer's tap button to exit set-up mode, and release the wireless controller's on button.
Repeat steps 1-2c for each additional dimmer.
Testimonial: "BoomerP is a God amongst men. I cannot tell you how much I appreciate your help. It worked on the first try. Thanks for the fast response too!!!"
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
