If the wire comes from under the flywheel it is most likely the stator lead that goes to the rectifier/regulator for charging the battery...if the cust. said this was getting hot then there may be a short circuit in the charging system or the rectifier/regulator may be defective...if this model does not have a rectifier/regulator on it , then the lead most likely goes to the headlamps to power them up(only while running)
