SOURCE: I have a Canon PIXA
You can see/downlaod the on screen manual from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15604
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: can't find "enlarge/reduce copy"
Scaled printing
To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'. You cannot use this setting with borderless printing.
I hope this information allows you to resolve this issue.
For Windows Vista
For Windows XP Home Edition
For Windows XP Professional Edition
For Windows 2000/Me/98
Please be aware that you can freely access Canon's online support solutions site by clicking here
If I've managed to answer your question, please take just a moment to rate this post. Thanks!
SOURCE: Trying to copy something and this error 2200 pops up and states refer to user guide
Hi
This is a scanner lock issue. You may try the following:
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Try a test scan now. If the error reoccurs, then try the below:
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO and using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
If the error still occurs, you may insert the cartridges one at a time and re-check..
hope the above info is of use to you.. try out..!!
