Question about Homelite Mighty Lite Lawn Trimmer
I was given 2 weed eaters, the z830sb, and the d630cd. I need to know what the gas and oil mixtures are for these units.. Thanks Jim
  • 3,074 Answers
32:1 should be a good mixture for the homelite weed eaters. here is a thread on it, hope it helped Tim:
ttp://forums2.gardenweb.com/forums/load/tools/msg1011591014681.html?13
Posted on Apr 24, 2011
Testimonial: "That was fast.. Thanks Tim....."
SOURCE:
Gas to oil mixture for 1 gallon of gas
most of my 2 cycle machines are 50-1 which amounts to 3 ounces of oil per gallon of gas. If 32-1 than it would be 4 ounces of oil per gallon of gas. Hope this helps.
Nov 26, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
I added 0.4 oz of oil to 1/2 gallon of gas too much to mixture. How can I dilute the mixture without starting over?
??? Take a gallon gas can, pour the I/2 gallon oil/gas mixture into it and then add the correct amount of undiluted gasoline to the correct mixture. For instance, if you need a .2 oz/I/2 gal ratio then add 1/2 gal gas to what you already have. Remember, it is always better to have a little too much oil than gas.
Jul 30, 2014 | Husqvarna Weed Eater 26 In Deck 190 CC...
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What gas mixture (oil to gas ratio)
40:1 3.0oz. of 2 cycle oil to 1 Gallon of gas
Jim
Aug 11, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Did not get an owners manual with my 33cc gastrimmer need to know the gas oil mixture .
40:1 = 3.2 oz of 2 stroke oil for every gallon of gas
Link to manual is below http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
May 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
My weed eater wont turn on it keeps turning off as soon as turned on it is really frusterating sorry if i spelled that wrong
Most two stroke engines in weed eaters require a premixed fuel combination of gasoline and two cycle oil. I am assuming you have a gas model which needs a gas and oil mixture. A possible problem is the choke is turned on, and once it starts you need to move the choke to run. Another possible problem is the gas oil mixture is incorrect, and you may need to remix the fuel to the manufactures recommendation.
Jul 23, 2010 | Garden
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
473 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
