Problem started recently when i turn on the phone, screen tells me that application closed. Application Watcher MainThread. Reason code USER reason number 11. Alos it tells me on Information not enough memory. Checked my memory Internal memory is 27 out of 156MB and Memory card 49 out of 467MB
Friends, this I got from allaboutsymbian website. And I already try the Test1 and it works!!!
Hope this could be much of help......
~~o000000o~~
I had the exact same problem and have solved it by updating the
firmware and reloading my settings from at saved bile, but it is rather
time consuming.
The solution by deleting all the messages in the inbox worked perfectly fine
Though nothing haapend when i only deleted the outbox and sent.
I assume that the problem is caused by the message server (the small program handleing you enter to send and read messages)
I descuvered that when my phone was put into offline mode, and
re-entering to normal mode , I could not open the message server.
After deleting all messages this problem has been resolved aswell.
Maybe the message server is having problem handleing to many messages.
The amount of space left on my phone was not a problem eather, arround 30 M and the insert card was empty.
but i had over 1300 messages in my inb ox when the problem started occuring.
If any ojne else is experiencing this problem, pleace keep on debugging and tributed with more result.
This will make it easyer to conclude on the results and finally determine why it is happening, based on when.
Test1 : (Is the issue resolved only when inbox being emptyed)
Here is what you do :
1. Delete all you messages - 1 in your inbox,
2. Restart the phone,
3. Send an sms to yourself.
4. Write a reply on this threat weather youi got the message or not.
if it is not resolved. please continue with 2. test
Test2 : (Is this allways resolved by emptying the indbox)
1. Delete ALL you messages in the inbox
If the problem is stille not resolved then you have to reset the phone.
Test 3.
First of all, you must save all you phone settings, phonebook
sms(despite you just deleted them all, save it anyways!) phone
settings. etc.
and then reset it.
1. Save all files
2 Reset you phone by typing in *#7370#.
3. Restart the phone,
4. Send an sms to yourself.
5. Write a reply on this threat weather youi got the message or not.
If this works, then restore one of the save configurations at a time and test weather it still works.
Test 1 worked perfectly for me. I have P990i and apparently they have the same bug. Actually what i did, I deleted most of your msgs and the important ones i was able to move them to another folder. as soon as inbox was empty, new sms started to be received! Therefore important sms can be moved to another folder. the fix is to empty the inbox.
thanks for your support.
I use the Tip #3 and my C.p is already fix tnx for fixya.......
Hi Friends, I have also faced the same problem from past one week, and was feeling bad about this msg that was frequently occurring by it self on my ( Sony Ericsson p1i ) and its
stopping all my incoming msg until and unless i re-start my phone the problem will not be re solved, and after re-start it starts again and again after 5 seconds.
Kind of msg that appears
in the phone:
(Application Closed)
Application = Watcher Main Thread
Reason Code = User
Reason Number = 11
<continue>
plz do some on mail me the solution for this...
I have the same problem
I dont know if this would help others who may have the same problem as I did with my P1 but what i did was to just take out my sim card and put it back and turned on my phone and viola no more message application watcher ...etc. Hope this will help. I didnt take the advise of doing a master reset.
exactly the same
I have a SE p990i and have exactly the same problem also. I hanged to new sim card, updated to new ATT network, and now the problem is worse. Error message is now almost continuous, plus the phone has started turning itself off :-((
i've also updated the software of my phone but there is no solution . . .
ya, the same problem, and it continues hundreds of times, i cannot receive msg.
Hey guys Im in Germany, also have a Sony P1i fon and have the exact
same problem with the WatcherMainThread, I also cant send any sms, they
are all pending on the sent folder. When I turn my fon off suddenly I
get 15 sms from the last days or weeks. How come noone knows anything
about it? Is it a virus, a trojan horse for mobiles??????? Who is
watching and what, sms only maybe fon calls as well?? I will check here again if ever someone knows something useful.
I also hv the same problem..went back to sonyericsson service centre here and they have no idea as well....This problem really makes me want to change my phone to other brands. Damn it!
Same problem. Precisely same thing is happening. It happened a fort night ago. I kept pressing "continue" and after 4 days the problem solved!!!
Now it has recurred.
Another observation, when I switch on the phone, pending message pour in (when this message occurs...reason Application Main Thread etc..., the messages stop coming).
There is no other problem...
Holla, I had a same problem, it appear when I restart My P1i. It blocks all the incoming message but after restart all pending message received. Did anyone try to format the phone? Is it works?
Just like what everyone else in this thread has been saying... I only have 70 messages in my In box, 22 in the Sent box, 0 in the Out Box... What's going on and how do I solve this?
