2003 Mitsubishi Eclipse Spyder Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 mitsubishi spyder horn dont work - 2003 Mitsubishi Eclipse Spyder
Anonymous
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Apr 23, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
257
Questions
0
Helped
74204
Points
799
In many cases, a blown fuse is the reason a horn does not work. Locate your fuse box. The specific location can be found inside your owner's manual. Inside of the fuse panel, you will find a diagram of the fuses. One of the fuses will say Horn. I recommend changing the fuse. If you do not know a lot about changing fuses, a auto parts store should be able to help you out. Hope this helps!
1helpful
Where is a Mitsubishi eclipse spyder 2003 wiper relay ?
The two relays for the front [main] wipers are part of the front ECU [engine computer] and are not serviceable separately. The front wipers are powered by a 10 amp [#22 in the relay box] battery hot fuse and a 20 amp [#18 in the junction box] & two 7.5 amp [#20 & #23 in the junction box] ignition hot fuses. The front ECU is located under the hood. It sits on top of the driver's inner fender well.
2answers
How to repair mitsubishi
Not being smart but get a manual or youtube it. You need to remember that the air bag is located near the horn device. You can be hurt by the bag if it inflates.
2003 Mitsubishi Eclipse Spyder GT convertible clicks when trying to start
Sounds like your battery is either flat, or has bad connection.
How to remove break light bulb in 2003 mitsibushi spyder
Check the brake light switch located on the brake pedal arm. Its above the pedal under the dash and has a connector with several wires attached to it. The switch is either bad, broken, or out of adjustment. If you have to step on the brake to shift out of park there is also a another switch located there as well.
2answers
My 2003 mitsubishi eclipse spyder anti-theft system won`t shut down. I tried to disarm it according to the manual but nothing happens. I took the horn fuse out and it just changed the tone of the horn and...
disconnect battery and join the cables together for a while if that doesnt work then disconnect battery and call the breakdown truck to take it to the dealer who has the right diagnostic software to sort the problem out for you .This is not a home repair type job
1helpful
The horn on my 2003 Mitsubishi spyder has stopped blowing. I suspect an electrical problem as, recently, one or both of the horns would work PART of the time. Is this common?
Horns are pretty simple in their operation. I would more suspect a horn relay. I am not very familiar with your vehicle, but usually due to the electrical current used in the horn circuit, most manufacturers run the circuit through a relay. An easy way to eliminate your horn is to simply run a wire directly from your battery and touch on the horn contacts. The horn should sound when you touch the wires onto the horn terminals. Hope this helps.
How do you get the head rest out of the front seats on a 2003 mitsubishi eclipse spyder.
if there is not a button, then a good **** up will get them past the clips inside
3helpful
I have a 2003 mitsubishi esclispe spyder gt
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 1 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mitsubishi Expert? Answer questions, earn points and help others
