Have the same problem as many other people who posted. I can't pair my Motorola H700 to my Blackberry curve. The purple light stays on only a few seconds and the blackberry won't recognize the bluetooth device. I can't even get to the point where I have to enter a passcode. I've paired and used Motorola bluetooth headsets before without a problem. Can you help?
Http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
I just bought the Motorola H700 Bluetooth yesterday, I have the Blackberry Curve 8520. My problem is I hold down the connect button to wait for the purple light to come on, & it doesn't ?? This is really frustrating, it's fully charged, and I don't know what I should do ?
YOU GUYS F***IN ROCK!!! THIS WORKED PERFECTLY... I FORGOT HOW TO USE THIS DEVICE AFTER 2 YEARS... BUT THIS SITE SOLVED MY PROBLEM! NOW I FEEL REALLY STUPID CUZ IT WAS SO EASY! THANKS EVERYONE!!! HERE IS THE SITE:
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
What do i use for a numerical passcode?
SOURCE: having problems pairing motorola h700 with blackberry curve
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open theheadsetand pressand hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
I AM TRYING TO CONNECT WITH MY PHONE. IT ASKS FOR CODE, BUT I DON'T KNOW THE CODE
I had the same problem, I went to the site of the answer below and it worked great!!!
yes i do
Same problem -- and link below worked for both my Motorola H700 and HS850.....got both of them synced up with no problems!!!
