According to you, I can't get what is the problem exactly. So for solution you can see or download the user and service manual. You can download manual from www.yamahagolfcar.com.
Please provide more information concerning your question. Do you want a place where you can get these parts or? please provide more information.
Hello
The serial number of the Golf cart does no good to ID it. I need the model number and the displacement of the engine as well as the number of cylinders and what year it was produced..
Thanks fro the update on the specifics of the Golf cart. I do not have access to any information on this paticuliar model and engine, golf carts are a rare bird on this site. Sorry
We do all use the same basic search tools to find this type of information. If the tech specs you need were available for download you would have had them by now. I would suggest you buy a factory manual, they should be available at the link below.
http://www.yamahagolfcar.com/partsandser...
ADJUSTMENT
Although it is sometimes possible to reuse an old cylinder head cover gasket, in most cases it makes more sense to purchase a new one before beginning the procedure. Some vehicles may require the use of silicone sealant either with or without a new cover gasket. For more details, please refer to the cylinder head cover procedures in Engine & Engine Overhaul of this repair guide and refer to the gasket manufacturer's instructions.
Z24i Engine
See Figures 1, 2 and 3
For the intake valves: 1-4-5-8 valve clearance is 0.012 in. (0.30mm). For the exhaust valves: 2-3-6-7 valve clearance is 0.012 in. (0.30mm). The pivot locknut torque specification is 12-16 ft. lbs. (16-22 Nm).
Fig. Fig. 1: Check the valve clearance with a flat feeler gauge-Z24i engine
Fig. Fig. 2: Loosen the locknut and turn the adjusting screw to adjust the valve clearance-Z24i engine
Fig. Fig. 3: With the No. 1 piston at TDC, adjust the top set of valves FIRST; with the No. 4 piston at TDC, adjust the bottom set of valves SECOND-Z24i engine
Fig. Fig. 4: Cross-sectional view of an installed hydraulic valve lifter-4 cylinder engine
Fig. Fig. 5: Cross-sectional view of an installed hydraulic valve lifter-6 cylinder engine
Year 1993 (Yamaha)
Model - G8AJ
Engine - 4 stroke, Gasoline, OHV (J38)
Cylinders - Single
Displacement - 285cc
Pls let me know if you require any more info...thx, Brian
Year 1993 (Yamaha)
Model - G8AJ
Cylinders - Single
Thanks for trying! Should I try another expert or do all of you technicians access the same information database to respond to assist with inquiries ?
Brian
Hello rockmeister...my auto mechanic friend is doing an elderly neighbour a favour, who relies on his golf cart to get around his lakefront neighbourhood. He is replacing the piston as well as the rings and requires the following info (without having to purchase a service manual @ $49.99 + $30.00 (min.) shipping charges):
1) Piston clearance
2) Valve lash clearance or adjustment
3) View of the timing marks
Year 1993 (Yamaha)
Model - G8AJ
Cylinders - Single
