Hi. "Press and hold the "left arrow" key. Press the "Setup" key and release both keys. Display should say "Enter Special Key Combo" 1. Press and release the right arrow button until the display says "System Configuration Menu". 12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
If that does not work try the procedure below:
Press and release the "OK" button
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press
and release the "CANCEL" button as many times as necessary, so that,
either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait
30 seconds for the power to get discharged and then plug the power
cable into the wall outlet first and then into the back of the printer
10. Turn
the unit on. The printer may display message "USE POWER BUTTON TO
SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK
INITIALIZATION PROCESS". Allow this process to complete and do not
interrupt. Once the initialization process is complete, the printer will
print out a Diagnostic Page.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
You can try this: Press and hold the "left arrow" key. Press the "Setup" key and release both keys. Display should say "Enter Special Key Combo" Press and release the "OK" button 1.Press and release the right arrow button until the display says "System Configuration Menu". 2.Press and release the "OK" button. 3.Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 4.Press and release the "OK" button. 5.Display should say "Hardware failure status: Clear. Press OK to clear". 6.Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 7.Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8.Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9.Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10.Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. 11.If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use. NOTE: If the error is still there, or reoccurs replace the unit.
To Fix this issue follow these steps to reset the printer. This will reset the Printer back to default settings so you will have to set it back up again.
Steps: 1. Unplug the power cable from printer while the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
3. Just turn on the printer and configure your printer new
SOURCE: I have got an error code, it reads 0xc18a0201. How do I resolve it?
Follow the steps on this HP link to reset the printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=uk&lc=en&dlc=en&product=1153481
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
