Vtech Cordless 6041 Phone Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ALL 3 OF MY CORDLESS PHONES SAY OUT OF BASE/RANGE/NO POWER...WHAT GIVES? NONE WILL GIVE ME A DIAL TONE!?
Anonymous
Level 2:
New Friend:
  • Expert 35 Answers
  • Posted on Apr 23, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
35
Questions
0
Helped
5476
Points
109
Two steps one be inte range of the fone step 2 try to increase the hight of the place of the phone by wich you can get more coverage
HOW DO I LIKE CORDLESS PHONE TO BASE
That is a fully automatic function, if it is not giving you a dial tone either the phone is defective or the base unit is.
I have uniden dxa1850 series phone. It was working fine, but now I can't get a dial tone. I tried the basic fix of unplugging and removing but it still does not work
Check that you have power (eg. Led indicator is on) to your Base station.
If you have power to the base station and you still do not have a dial tone, plug in a non-cordless handset to the phone socket and see if you have a dial tone on yor non-cordless handset, then you have a faulty base station.
Hope it helps and good luck! let me know how you go!
No dial tone! what do i do??
with your main base plugged in you should have lights on it, this means your getting power, now check if your phone wire is plugged into your base all the way. If you pick up your phone and hit the center button it should light up the phone and read connecting, then give a dial tone. if not i would try another phone in that same wall jack and try. If another phone works fine and all your connections are good try replacing phone cord to base and try it. If still no good check that phone in cradle is hs1. handset no. 1 and try. hope this works
19helpful
2answers
Handsets give 3 beeps, no dialtone
Either they are not powered up, or the mother has lost power.  Make sure the mother and children bases have power and leave the handsets in the bases long enough to charge.
3answers
Cordless phones wont work
Try to registrate to a base in the hs settings
should work,
No dial tone
I have no dial tone on my phones. I can receive calls and my answer machine works ok. I plugged another phone (an old phone) and I have a dial tone on that phone, but not on the new ones
3helpful
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
