Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heater displays error code E06 - what does this mean? Is it something I can address myself or do i need a service tech to address?
John Prohaska
Level 3:
President:
  • Sta Rite Master 1,378 Answers
  • Posted on Apr 23, 2011
John Prohaska
Sta Rite Master
Level 3:
President:
Answers
1378
Questions
Helped
689088
Points
3511
Thank you for posting your question here on Fixya.com.
Page 43 of your manual, found here suggests both E05 and E06 errors mean the issue is related to "...(the) fuel supply, thermal regulator, check for correct orifices, etc...". It also touches on the possibility that if the unit was converted from NG to PP or vice-versa that the orifices are not correct.
Start with these two areas...if you need additional assistance please comment to this answer with details from what you find while checking these areas and I'll try and help you from there.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
  • Neil Heath
    Neil Heath Jan 20, 2022
    My heater is getting e06 too. When it first starts the temp says it’s 052, instead of 000. This would be a thermal regulator issue I guess
David Spradling
Level 3:
Top Expert:
  • Sta Rite Master 13,522 Answers
  • Posted on May 22, 2022
David Spradling
Sta Rite Master
Level 3:
Top Expert:
Answers
13522
Questions
0
Helped
929217
Points
28390
Possible temp sensor bad or going bad
I have a 512 mb fsdGT compact flash card and my MR8 will not format it?
This is why we need 'make model (what is is)'.
https://www.google.com/search?q=MR8
and here is the answer to the EO6 Error
The error code E06 means Cover Open. It is displayed if the scanner's top cover is open, or the top cover sensor has failed. Close the scanner's top cover.
Jun 24, 2013
Error Code: E06 ' Brother
or
Dryer Error Code E06 ' Bosch Home Appliances
https://www.bosch-home.ca > service > get-support > su...
Your Dryer shows error code E06? The experts from Bosch Home ... Bosch Home Appliance Service. Outstanding service - before and after the purchase.
It is likely that the card you are using has exceeded the formatting capacity of the camera, but you can Google
make model specs
or
make model manual
My old Canon S10 Digital Camera came with an 8MB Compact Flash card and I upgraded and bought a 32MB card. That was huge back in the mid 90s (and expensive), and although compact flash cards are seldom used in cameras now, they are used in other applications like increasing RAM in printers.
What does code E06 on display screen mean Thankyou
E06 is a pump fault.which means something has blocked the pump.a coin.hair clip.bra wire.etc there should be a flap near bottom of machine to access it.unscrew "WATER WILL COME OUT" feel inside and clear blockage.unplug first.u may have to pull the pipe off the pump depending on whats in it
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
2answers
I lost my manual for Snappy Chef. I do not know if E06 appear what does it mean.
LOOK UP ON LINE TYPE IN E06 OWNERS MANUAL OR E06 PARTS MANUAL MAYBE ONE OF THOSE WILL SHOW YOU WHAT IT MEANS THE E USUALY STANDS FOR ERROR. THE 6 COULD MEAN THE OVEN OR BROILER OR A CENCER.
Feb 02, 2015 • Ovens
Mastertemp e06
check gas pressure this heater overheated and improper gas will do that
2helpful
E06 and E01 error code
E06
Paper output cover is open. Close the paper output cover.
Error code 6
Good Morning sewblessed - Generally, error code E06 means that when the unit is in the dry cycle, the control does not receive the proper speed feedback from the lower fan. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, then more than likely the lower fan will need replacing and I would recommend connecting with an experienced appliance repair tech to assist further.
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
