The speed display will flash whenever you have the charger plugged in. Either in the back or in the joystick. Hopefully you didn't have them both plugged in at the same time. If after you unplug the charger you still get the flashing speed lights then you have an inhibit problem with the chair. The inhibit function will keep you from being able to drive the chair while charging. This repair is beyond anything you can do and must be referred to a Pride dealer or Repair service Hope this helps you
I recommend you to look for camping chairs that have armrests, a back and padding on the seat and on the back. You should check if the chair is comfortable for you and if it's easily folded.
