Troy Bilt 175HP Manual 42" Riding Mower Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DOES TROY BUILT PONY MODEL # 394358 HAVE A OIL FILTER 17.5 HR 42" CUT
Roy Cagle
Level 3:
President:
  • Troy Master 1,545 Answers
  • Posted on Apr 22, 2011
Roy Cagle
Troy Master
Level 3:
President:
Answers
1545
Questions
Helped
913430
Points
4781
Your owner's manual indicates to change the oil and replace the oil fitler on page 19 as part of the regular maintenance schedule. Whether or not your exact engine application does indeed have the filter is the engine manufacturer's option. Here is your manual.
http://www.troybilt.com/wcpics/TroyBiltUS/en_US/wwcm/769-03502.pdf
Josh Ya
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 01, 2016
Josh Ya
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7462
Points
11
Mine does not. I purchased it at Lowes. Asked Lowes for an oil filter and they sold me one, but I found there is not one on it, so I have to return the filter.
3answers
Troy Built Pony- will move in reverse but not forward.
There could be several reasons why a Troy Built Pony lawn tractor will move in reverse but not forward. One possible reason is a faulty transmission. The transmission is responsible for transferring power from the engine to the wheels, and if it is not functioning properly, the tractor may not move forward. Another possible reason is a broken or worn out drive belt. The drive belt connects the engine to the transmission and if it is damaged, the tractor may not move forward. Additionally, a damaged or worn out pulley can also cause the tractor to move in reverse but not forward.
To diagnose the issue, it is recommended to check the transmission fluid level and condition, inspect the drive belt for any damage or wear, and examine the pulleys for any signs of damage or wear. If any of these components are found to be faulty, they should be replaced immediately.
In conclusion, if a Troy Built Pony lawn tractor is moving in reverse but not forward, it could be due to a faulty transmission, a broken or worn out drive belt, or a damaged or worn out pulley. It is recommended to inspect these components and replace them as necessary.
Oct 02, 2022 • Troy Garden
Troy bilt pony riding mower
spray some carburetor cleaner in the intake and try to start it if it starts for a few seconds the carburetor is dirty and needs cleaned. put a new needle in it they are cheap and will solve your problem. take the spark plug out and try to start it. if it spins over freely and blows gas out the hole it is the needle in the carburetor. you may want to check the valves, they may be out of adjustment causing hard starting.
Jul 17, 2017 • Garden
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 • Troy Garden
Where is the model # on troy built tiller
If this is a genuine Troy ... (built in Troy, New York, by Garden Way) find the information stamped on the transmission housing left or right near the tire.
My troy built is several years old and recently the tires went flat. I know there is a transmission disconnect but the only manual I got with it was a Briggs and stratton motor guide. I never paid...
There is no actual transmission disconnect on the mower. If you put in neutral the belt would need to slip on the pulley in order for it to be pushed or roll freely. This usually doesn't happen.
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
3answers
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
