TDK DA-5900 2-Disc CD Recorder Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote freplacement - TDK DA-5900 2-Disc CD Recorder
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Apr 22, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2764932
Points
24828
1helpful
Discovery 3 p0098 fault solution
code p0098 refers to intake air temp (IAT) sensor 2 ---circuit high input===causes--wiring short to positive ---IAT sensor---ECM
freplace the IAT sensor
2helpful
3answers
Front brakes dragging, new pads and rotors 2k ago
couple of things to check. raise vehicle and support with front wheels off ground. spin wheels by hand .should have light drag and both sides should be the same. if not,check that the brake pedal is properly adjusted into brake booster/master cylinder. if that is ok then the calipers maybe sticking and both should be replaced. inspect front brake hoses for restrictions.
3helpful
I am trying to freplace the flasher relzay switch on mt 2003 camry, I cannot locate the switch
The flasher relay in the Camry is in either the drivers side kicker panel (directly to the left of your left foot) or underneath the driver side dashboard in front of your knees. If you have the replacement relay already you will easily identify the old one needing replacement. Good luck and rate this solution if you find it helpful.
Thank you!
KW-NX7000 NO GPS SIGNAL OUT OF THE BLUE
check these options
BAUD RATE AND PORT are set correctly. most gps now have a search function which selecvts the correct options. If not consult manual
Check battery capacity as this is a major factor too low wont pick up signal. freplace if necessary.
claer view of the sky.. not inside
Could even be more serious than that burned out chip and that;s expensive to repair
4helpful
3answers
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Unit is dead i have power to control board but no out put need wiring diagram
Its most likley that you will need to freplace the main control. I have run into that problem quite a few times, and by replacing the control solves the problem.
Top TDK Audio Players & Recorders Experts
August Brown
August Brown
Trond Baarli Olsen
Trond Baarli Olsen
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
