Question about Proton MM2701VT 27" TV
I have Samsung HL-S5087W for about 5 years and it is turning off by itself-any suggestions?
    Novelist:
  • 123 Answers
I hope your TV is getting ''off '' by itself when you are trying to turn ''on'' - not when you are watching TV...........then following is the situation ..........IF LED IS BLINKING then---- usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ..........IF LED IS ALSO OFF then on main board in power section area some component is deffective ... MAIN BOARD SHOULD BE CHECKED COMPLETELY........ so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore.....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact samsung service centre.........
Posted on Apr 22, 2011
SOURCE:
HL-S5087W IS WORKING RIGHT NOW, BEAUTIFUL PICTURE BUT AFTER 20 MINUTES THE PICTURE GET OUT. THE LAMP IS NEW.
I went through the same exact thing. I had to replace the DMD board. No problem after that.
Feb 26, 2015 | Samsung HL-S5087W DLP TV
My Samsung HLS5087W keeps turning off by itself.
need to replace the lamp to correct this issue
Dec 17, 2010 | Samsung HL-S5087W DLP TV
HL-S5087W has become dim in picture
if the colors look good and its just dim its the lamp. usually the lamp will show signs of being bad by looking at the base of the shaft in the middle if its discolored or warped the lamp is bad
Jan 30, 2010 | Samsung HL-S5087W DLP TV
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Nov 19, 2009 | Samsung HL-S5087W DLP TV
I HAVE A 50'dlp SAMSUNG TV-HL-S5087W THAT TURNS OFF
probably a bad (intermittent) control board.
Nov 14, 2009 | Samsung HL-S5087W DLP TV
Color disappears from DLP display
the problem here is the crt cicuit unplug from the wall take off the back its the cicuit board thats pushed on to the tv screen pull it off. you will see R G B its the B one thats faulty it looks like a transistor. call an engeneer and he will put a new one in for you i hope this helps you???????
Apr 23, 2009 | Samsung HL-S5087W DLP TV
Turn tv on and then it will turn itself of can immedately turn back on it is a 50 inch SamSung one year old can any one help with this problem
do a voltage check the transformer & the bridge rectifier and the whole off the power supply use a meter ther may be power starvation
Mar 11, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W wont hold the settings
i think problem is with your tv's system control section and please do not do anything if you are not familiar with electronics.
if yes please find the sys control section and find the serial eeprom
thn come again.
nuwan.
Jan 19, 2009 | Samsung HL-S5087W DLP TV
Proton MM2701VT 27" TV Logo
80 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
