Question about Video Game Consoles & Games
My dsi's L and R key is broken. i try not to use them. but, i really need both keys.the L key sometimes works. but my R key is broken.
    New Friend:
  • 52 Answers
Is it really broken or is it stuck? You could try using pressurized air on the shoulder buttons to see if they will "loosen" and will be usable again.
Just buy a can of pressurized air and insert it in the corner of the button. The pressurized air SHOULD loosen up the buttons if they are a bit tight/hard to use.
ps. you could also try biting the shoulder buttons out...that works too.
If it really is broken, like, it looks and feels like it should but the action isn't being registered, then maybe you have to go to a technician/Nintendo especially if it is still in warranty.
Posted on Apr 22, 2011
SOURCE:
Master key wont work
Find the Nintendo phone number ad give them a ring then on you DS DSi 3DS DSi exel or 3DS exel go to parental controls and say i forgot twice and the person on the phone will give you a master key the hacks dont work unless you have a wii
Mar 30, 2014 | Nintendo DSi Blue Console
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
ERROR CODE FOR DSI 052010-1
Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings; manually assign an IP address to the Nintendo DS.
Don't know how to find your router's security key?
Manually assign an IP address to your Nintendo DS.
For more help visit cbrtechsolutions
Jul 01, 2012 | Nintendo DSi Black Console
Hi, My Nintendo Dsi camera stopped working, it says "An error has occurred" and sometimes my dsi shuts down by its self i really need your help ! Thank You
I think the ndsi of yours need to be fixed ...it might have a software issue......you can get nintendo dsi fixed from nintendo repair shop or ask them what the issue is.... and hopefully it will get working!
Sep 25, 2011 | Nintendo DSi Black Console
We're trying to set up a wi-fi connection for a Nintendo DSi. When I enter the security code for my wireless Internet connection, the DSi doesn't recognize it.
I'm think that you need to enter a code, I have attach a doc that should help you out. I found this link at Nintend.com
Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
Jan 23, 2011 | Nintendo DSi Black Console
My wep to get internet to my nintendo dsi is not working can you send my a wep key that really works
Your WEP key is yours only, no one else will know it. Usually it is on a label on your wireless router. Have a look at the router and see if you can see it. If not you may need to try and reset your router with the reset button and then try connecting again. I am not 100% sure if this will reset the WEP key, some do, some don't. Unfortunately if you have forgotten it it can be difficult to retrieve it.
Hope this helps
Nov 21, 2010 | Nintendo DSi Black Console
Need master key for nintendo dsi
need to obtain master key for nintedo DSi
Aug 15, 2010 | Nintendo DSi Blue Console
Dsi will not connect to internet it says that i need correctsecurity key where do i get the security key from?
The security key is the password for the wireless router that your trying to connect to. The password is usually written on the router itself.
Jul 16, 2010 | Nintendo DSi Black Console
Dsi passwor and pin
what you have to do is try and get a master key to unlock your pin. (maybe in the shop you bought it have a master key or you will have to look it up on http://www.nintendo.com/ for a master key! hope i helped!
Feb 27, 2010 | Nintendo DSi Black Console
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
