SOURCE: Wont hold charge, light comes on though
hey , well i think an hour might be normal , mine seems to only last as long , but it says in the manuel that when the camera is not in use to disconnect the battery because even with the power off it still discharges.
hope this helps
SOURCE: Samsung SC-D363 won't charge battery
well , just make sure that the camera is set to the off position when charging , otherwise i dont think it will charge properly.
hope this helps
SOURCE: Entire camera is locked up
THIS IS A PROBLEM WITH SAMSUNG SCD 353 LET ME NO IF U NEED MORE REPAIRS
SOURCE: Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
SOURCE: My blackjack wont charge
I did a hard reset because i was having the same problem with a new battery and a new charger. I took my sim card out first to prevent any possible data loss. then followed the following steps:
after i did that i plugged in the charger and it worked perfectly. this is the last step that you would do after updating the software on the BJ
