Casio Keyboard Ctk-481 Ctk-631 Ctk-651 Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get my casio ctk 651 to act as a midi keyboard with my maudio fast track pro and live 8 software on my pc Windows 7 CPU 3 GHz and 4 GB Ram.
Fred Yearian
Level 3:
  • Casio Master 5,603 Answers
  • Posted on Apr 23, 2011
Fred Yearian
Casio Master
Level 3:
Answers
5603
Questions
Helped
2249801
Points
16163
Make sure you have set the powerchord/MIDI to the MIDI mode.
Where can i get a ctk 481 driver
CTK 481 only has MIDI-IN and MIDI-OUT ports & no USB. So you need to buy a USB-MIDI interface (cable-like) preferably one that is class-compliant for you OS. Class-compliant device do not need drivers (PCs, MACs, IPAD).
2answers
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
2answers
I bought a usb to midi device for my Casio CTK-491, but none of my VST's or DAW's receive midi information from the keyboard, The programs see that there is a midi input and output but the computer...
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
2helpful
I can´t find CASIO CTK-810
Vista has SO MANY compatibility problems that it MAY be futile to try finding a specific driver for thaat synth. Consider going to Windows 7. HOWEVER, a MIDI driver is a MIDI driver and anything specific to the synth is really not truly just a driver as such, but a user interface type program that may contain things like voice editors and other functions specific to the synth.
4helpful
2answers
Casio CTK-651 keyboard wont switch on
An internal fuse is UNLIKELY.
More likely is either a bad connection/connector at power input or a bad or intermittent power switch.
Jun 24, 2010 • Casio Music
1helpful
Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
20helpful
2answers
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 • Casio Music
3helpful
3answers
Not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
MIDI Keyboard note delay problem, not latency problem PLEASE HELP
You are suffering from midi latency. There is a good article about this at www.thewhippinpost.co.uk/latency.htm There is also some good advice there.
3helpful
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
