Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Dear,
You Can Unlock Your HTC Droid . Call Your Network Provider To Ask Your HTC Phone Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy HTC Imei Unlock Code From Third Party. Many Site Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
Download z4root using Google Search and you will find the link to download/install z4root app for your Android.
Once installed, run z4root and do a TEMPORARY root as that is all that works right now with the HTC Incredible.
It still roots your phone and gives you full access to everything (root access; hence the term "Rooting" your Droid). The only thing that is virtually impossible to do is get a custom ROM running on one unless you connect it via USB and root using the 1 Click Root Method for HTC Incredible (Search Google for it.).
I hope this helps! Enjoy your Incredible! If you need anything else, please let me know!
Best Regards,
James Trageser
It is very easy to unlock your HTC cell phone simply enter unlock code through mobile keypad,You can get unlock code at cheapest rate by HTC UNLOCK CODE provider.
*Visit http://www.htcimeiunlockcode.com for HTC Unlock Code with Instructions.
THANKS ! ! !
