Question about Stanley Utility Knife
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
    New Friend:
  • 27 Answers
At the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Posted on Apr 21, 2011
    New Friend:
    Problem Solver:
  • 7 Answers
I still cannot figure out why stanley did not even bother to include instructions.... I had to go to You Tube for the solution....
http://www.youtube.com/watch?v=B8Q1p-8jkyE
Turns out it's quite easy!
Posted on Jul 31, 2012
6ya staff
SOURCE:
How do I remove the original packaging from the fatmax
I agree. The packaging is ridiculous.
I removed it by grasping the packaging and pulling (very hard) from the blade end (bottom left as looking at it) straight out. This stretched and tore the plastic "paper" and pull the knife free.
Feb 01, 2014 | Stanley 10-778 FatMax Retractable Utility...
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Mar 06, 2011 | Stanley Fatmax Xtreme Retractable Utility...
How do you put blades in stanley fat max extreme razor knife
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Feb 26, 2011 | Stanley Garden
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Change blades I just need a picture /instruction for blade change
The gold looking circle on the side of the utility knife. Just unscrew that and it will pop open then you can change the blade. I looked everywhere and am unable to find the instruction or picture. I own one and that is why I am answering this for you. Please rate
May 31, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
Stanley  Utility Knife  Logo
1,508 people viewed this question
Top Stanley Cutter Tools Experts
Joe Garcia
Joe Garcia
Joseph Hoffmann
JOHN LAPIER
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
