Tv turn on and off by itself and flips channels. I use the remote to change the channels but it wont work also I unplug it that doesnt work eitherTv turn on and off by itself and flips channels. I use the remote to change the channels but it wont work also I unplug it that doesnt work either
AnonymousAug 11, 2008
i have the same problem as describe above can someone helpi have the same problem as describe above can someone help
This tv will come on for 2 seconds shut itself off for 2 seconds and will search for channels on its on...This tv will come on for 2 seconds shut itself off for 2 seconds and will search for channels on its on...
You can't post conmments that contain an email address.
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
1. Turn your TV ON.2. Hold down "Code Search" until the red light turns on.
3. Click the (+) Channel button once each second, until the TV responds by flipping a channel.
4. One the channel changes, press the, "ENTER" button.
5. Code is saved!
Okay there is something wroung with the frount panel there may be debris in where the button is depressed or seomthing is depressing the button or it may be just going out on you.
1. take off the frount cover and examine the channel up and down make sure its clean and there are no debris.
2. if that does not work replace the controller board aroun $65 bucks.
I do not know your zip code but you can give these folks a shot www.teexp.com you can call and ask how much it would cost to replace this controller even though they might not work in your area they still can give you a price.
the v hold is going out that causes the picture to roll if only 1 channel does that then call the cable company.If it's more than one then find the v-hold in the back and turn it slowly till it stops,if it gets faster turn it the other way
My sony HD TV started automatically flipping to the memory stick screen by itself. I thought maybe the remote was malfunctioning so I took the batteries out of the tv's remote as well as the cable boxes remote. Still does it. If I hit the memory stick button on the remote to switch off the screen sometimes it goes back to TV screen and sometimes it doesn't. Eventually, it flips back to the memory stick screen. Is this a known problem for this TV?
your problem in system control section
check aft &tuning ckt &its voltages
check for loose contact in above ckt
check tuner
thanks
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
