"Please contact Hamco Heating for details of retailers in your area.
If you would like to know more about our services
please phone (057) 93 21302
or email [email protected]
Plug your machine in and push the menu button again and again are the numbers changing from program to program? If not push the start/stop button with no ingredients in it and if it starts kneading wait a few seconds then push the start/stop button again UNTIL IT BEEPS AND STOPS. Unplug the machine and plug it in again and the program 1 should show again, just push the Menu button until you see the number 9 program. Did that work?
Hi
Your internet (mail) set up has 2 different parameters . One for Receive and second for Send.
The msg you ve is ror Send , reminding you have not set it properly
Open your Pc mail setup menu and find the working
values there and insert these paramaters into phone setting. Thats it,
Take care and please remember to vote us .thanks
You can download the manual for your mobile from the link below
Download here
If you require more assistance feel free to reply to this post
Thanks for contacting FixYa!
Regards,
BA
If you are in Nothern Ireland you will need a UHF antenna, and Republic Ireland you will need VHF and UHF antenna to recieve off the air signals.
Connect the antenna to the back of the TV. Turn the TV on, select "menu" button on your remote and slect TV from TV/Cable menu press enter, go to main menu and select channel set up menu and select auto channel button and when finished press menu button, check your user manual for details.
OR, you could go to the programming phone and program it yourself.
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
#1. try to hold the menu key until some window program appears....( same like Windows task manager on PC if ctrl+alt+del was pressed )..
then close every program with <select> scroll down <exit>...
#2. Move all message content to MMC :
<message> <seting> <other> <memory in use> <memory card> done.
