Canon PIXMA iP2200 InkJet Photo Printer Logo
Anonymous Posted on Apr 21, 2011
I have a canon pixma ip2770. I just had an ink refill for the first time but magenta ink won't work. I tried cleaning, deep cleaning, etc. but the other ink worked just fine except magenta. what should I do? thanks :)
  • Anonymous Apr 21, 2011
    do we need to remove the ink before soaking it in water?
Anonymous
Level 3:
Guru:
  • Master 352 Answers
  • Posted on Apr 21, 2011
Anonymous
Master
Level 3:
Guru:
Answers
352
Questions
0
Helped
98075
Points
1095
Sometimes after a refiling they cover a small air holes on the top of the cartridge when replacing the label. remove the label completely and try again.
Also the magenta might have been to empty for a refill to work correctly. There is a lower chamber in the cartridge that air can get into and stop the flow from the top section. This link below can help in that case. http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
  • Anonymous Apr 22, 2011
    No the ink can stay in the cartridge, just pull the cartridge out and soak it in as is.
Ip2770 black ink doesn't apperar on paper although there is no nitification of cartidge damage
you most proberbly have a clogged black catridge. try cleaning from the printer's maintenace tab. if it doesnt improve after a few cleans, do a deep clean. if it still doesnt work and you dnt feel like buying a new catridge yet, steam the nozzle of the catridge. these steps almost always do it, if not, just get a new catridge and voila!
Magenta ink won't print though cyan and yellow print okay after refilling for the first time. Also, everytime I remove cartridge (color) the print head is full of ink blot. (is this normal?) I have tried...
Sorry for the delay in my answer. No you do not need to remove the ink from the cartridge itself. Soak remove the cartridge and soak it as is. You will get a huge colour change in the water but it will not use any more than 0.1ml of ink
regards GM
The magenta won't work. i put a new cartridge, cleaned headers, test printed. all the other colors work find but, NO magenta comes out.
This sounds like you are using an aftermarket or refilled ink cartridge. If this is the case, try putting in a new OEM magenta ink cartridge and running the deep cleaning utility 3 times. This usually clears a clogged nozzle caused by non-OEM loaded inks.
Let me know if this clears the problem. Thanks.
Canon pixma ip4300 - magenta ink is recognized but not printing
Take the print head out of the machine and sit it in a saucer of very hot ( just off boil) water about 10mm deep for a minute. Take it out and sit in on a pad of paper towel to dry briefly before returning it and the cartridges into the machine. Give it a deep clean and try again. If still no good, the print head has probably had it.
1helpful
2answers
Color ink cartridge does not print in full colors
Canon printers do not like the refilled ink cartridges. After having ruined a few printers trying to "save" money. I went back to genuine Canon ink and have never had a problem since.
1helpful
Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
old marine
old marine
ZJ Limited
ZJ Limited
