Celestron PowerSeeker 127 EQ 21049 (750 x 127mm) Telescope Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you describe how to use RA and DEC to find objects. I can find the planets ect....
Joe Lalumia aka TelescopeMan
Level 3:
  • Master 3,186 Answers
  • Posted on Apr 21, 2011
Master
Level 3:
Answers
3186
Questions
Helped
952637
Points
7111
Once the scope is polar aligned move it to a named star that you can identify. Look up the RA and DEC for that NAMED star in any planetarium phone APP or a laptop running any planetarium software like the free software available at www.stellarium.org
Adjust the circles to MATCH the RA and DEC in the planetarium software, and lock them down.
Now you can use them to find other objects of known RA and DEC.
Manual for TwinStar 1000mm focal length telescope and equatorial mount
Equatorial mounts need to be polar aligned to work correctly. Once the scope is polar aligned (see manual or look online for polar alignment instructions), turn on the RA motor. Loosen your RA and DEC locks and find a object you want to view, The motor should keep the object in view for a while (depends on how good the motor tracks and how good your polar alignment is.) Spending 10 minutes polar alignment on my C8 keeps the object in view for about an hour without adjustment.
1helpful
Hi Joe, My name is also Joe and I just bought a Celestron AstroMaster 114 and need a hand with the elevation,inclination, declination settings(what should my gauges be set to) to star using the unit. Any...
Your DEC is the same as your Latitude--
Right Ascension does not matter for now. Polar Align the scope on the star Polaris-- read this:
http://arnholm.org/astro/polar_alignment/index.html
Once you are polar aligned, rotate the tube to a star in the sky that you KNOW the name of. Look up the Right Ascension of that star on a cell phone app or a laptop planetarium program like this one:
www.stellarium.org
Rotate the RA setting circle so it matches what the phone or laptop indicate. LOCK down the RA circle. Your scope is now adjusted to the sky and you can use the numbers on the DEC and RA to find other objects of known RA & DEC.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
I have a CPC11GPS telescope that was working the last time I used it, which was 6 months ago. It is in NEW NEW condition. I pulled it out last night, turned it on, allowed the system to align itself using...
The clutch is not engaging in RA. Maybe the gears are not actually meshing together? A loose worm gear?
You can open it up and look and see if anything obvious is loose. Otherwise it's a trip back to Celestron.
Someone told me that the Meade Lightbridge could be equipped with Go-To Tecnology.T/F?
PUSH TO -- encoders can be mounted on to the base RA and DEC. After aligning on two known stars the hand controller will "point" to objects in the sky.
http://www.wildcard-innovations.com.au/kits/pn-lb-16d-spec_describe.html
LX90 Dec pointing out by 4 degrees over run
Go onto www.cloudynights.com and post this in the LX member forum-- and or go on YAHOO groups and post this in the LX90 forum--
Are you absolutely sure that your TIME and DATE and DAYLIGHT SAVINGS (yes-no) are correct.
On my LX90 the first alignment star is always NOT in the eyepiece but everything is OK once I center both alignment stars.
RA will not track on Orion Atlas mount
Are you sure it's not actually working (tracking)-- can you hear the motor running?
I would contact Orion and make sure you have a manual for the hand-controller-- it may have a setting that turns tracking on or off.
http://www.telescope.com/control/main/
GOTO ERRORS MEADE LX200 10" CLASSIC
Most problems tend to be mechanical. Have you 'trained' the drive and set the backlash values? Those 2 can have dramatic effects on pointing accuracy. Also, if the optical tube is not in alignment with the mount, then nothing will work correctly. To check that, have the telescope in Alt-Az configuration, inside the house, loosen the RA lock, and shine a laser pointer on the corrector plate. as the telescope is rotated about the RA, the reflected spot should be steady. Adjust the DEC to minimize the diameter of the circle that is drawn. What is left, is the out-of-true on the DEC axis. That can be adjusted with the tube cradle alignment bolts.
2answers
Top Celestron Optics Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Celestron Optic Expert? Answer questions, earn points and help others
