Dehumidifiers Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My humidifier runs, but no water is collected. It will start and just keep running. Could something be clogged. The filter has been cleaned. It has sat not running through the winter.
Anonymous
Level 3:
  • Haier Master 43,501 Answers
  • Posted on Apr 21, 2011
Anonymous
Haier Master
Level 3:
Answers
43501
Questions
0
Helped
10844580
Points
101584
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
The humidifier runs but doe snot collect water.
Most of the time this is based on the humidity level in your home and what you have set the humidifier to remove. However, if the filter is dirty or clogged, the unit struggles to dehumidify the area. Removing the filter and cleaning it, may solve the problem. And while you're at it, check the drain hole or tube, that drains into the bucket for clogs. You will have to remove the bucket to do this. Even though you may not be able to see a clog, it may be there none the less. Using an 18" long, plastic Zip Tie that will fit into the hole or tubing is a good way to clear it out. Just do it gingerly and work it past the curve in the tubing. When you pull it back out, be prepared for water to follow it. Whatever you do, DO NOT use a wire coat hanger to clear the clog. Also, before attempting any of the above, turn the Master On/Off Switch to Off and unplug the unit from the wall outlet.
Hope this helps you solve the problem. Please let me know. Thanks!
1helpful
2answers
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
5helpful
Humidifier runs but does not dehumidify! any suggestions? i have cleaned the filter.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
2helpful
3answers
The humidifier runs but is not collecting water... so humidity level never drops.
My brand new frigidaire 50 liter dehumidifier has been on for two days and has not collected water from my damp basement. It is on the factory settings: high fan and "CO" (continuous).
1helpful
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Kenmore 580-52650100 65 pts./24 hour
Humidifier is fairly old. I put it on the curb for garbage pickup.
3helpful
3answers
Ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
