This is a common failure of the control board. It is often accompanied by a intermittently blank display. The board is no-longer-available but we can rebuild it for you at www.fixyourboard.com.
Control board part number: 8302967
SOURCE: error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
SOURCE: Code E6 F2
We repair a lot of control boards for this particular failure. Here's a link to a short article addressing this problem:
www.fixyourboard.com/techzone/ovens/e6_f2/e6_f2.html
Hope this helps you out!
Best Regards,
Bruce
SOURCE: e6 F2 error on Whirlpool double self cleaning oven.
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
SOURCE: whirlpool double ovens error message e6 f2
E6 F2 is always a problem with the control board. It can be fixed quickly and reliably at www.fixyourboard.com
E6 F2 Error Code = Faulty Control Board.
This is the most common board failure symptom and can only be due to the control board. Since the techsheet decodes this to “cancel key line drive open”, many people suspect the keypad is bad. The keypad is not causing an E6/F2. Based on years of experience, E6/F2 is never anything other than the control board….. Send the control board for remanufacture to FixYourBoard.com We offer these from our inventory, and repair them with a two year warranty.
