Just tripping the breaker should no affect your dimmer unless maybe malfunctioning or wired incorrectly or loose connection. It is hard to wire incorrectly, for there should only be two wires attached to the dimmer? Replace dimmer and make sure wiring is correct if not sure about wiring yourself contact local electrician for your safety. There are very good instructions inside the switch packages, make sure to buy a quality switch, Leviton is a good name I would lean towards faulty switch or loose connection but I'm not there. Good Luck Karen....
