LG Vu CU920 Cellular Phone Logo
Posted on Aug 16, 2017
I'm having trouble downloading pictures and videos from my lg vu cellular phone onto my computer. I've set the connection to mass storage device on my phone, and I have the usb connector cable. Other online sites have mentioned a memory card? Does any old memory card work? And where do I insert it at anyway? Also, I lost my installation cd. Is there a free download of it somewhere online?
Stephen Mintz
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 16, 2017
Stephen Mintz
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
127
Points
6
I am also facing this problem, Someone says that get online software file. Searching... I want to know more information. ShowBox App Download Show Box and Stream Movies for Free
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Jan 11, 2009
SOURCE: LG PHONE PICTURES INTO COMPUTER
If you bought the SD card from Verizon then you should have another card where you insert the card into the regular sized and it works that way. Good luck!!
Anonymous
  • 214 Answers
  • Posted on Feb 25, 2009
SOURCE: PC does not recognize Micro SD Card in LG CU500
The easiest solution is to leave it as 'mass storage', then navigate to it, my computer, mass storage, ect, Then just right click & open it. Now open your pictures, music ect. on your PC, drag & drop to the phone. That's how I do mine. You will be able to drop them into whichever folder you want. You might have to drop them into a folder on the phone then copy & paste them to the SD card after you disconnect from the PC. If you have more questions leave a comment, I'll be happy to help. Good luck.
Anonymous
  • Posted on Mar 13, 2009
SOURCE: LG Vu -how can I tranfer pictures?
It is quite a bummer, but you have to select one picture at a time, go to options, select move, choose memory card, select paste and then when you have moved all of your pictures over to your memory card you can get them on your computer via the data cable. I miss my sony!
Anonymous
  • Posted on May 08, 2009
SOURCE: i have the lg lotus and i want to upload videos
when you plug in connect the phone via the usb cord a window should pop up asking if you want to view the folder. select this option. when you click it, you should see four folders. dcim, music, email, bluetooth. click on dcim. your videos should be stored in this folder. just click and drag them into whichever folder on your pc you want them in. or, when you connect your phone it will give you four options. transfer music, mass storage, phone as modem, pict bridge. select transfer music. this should make the previously mentioned window pop up and you can follow my instructions from there. or, if you have you videos stored in the 'in phone' part of your phones memory you need to move them to your 'memory card' memory. just select 'options', then 'move'.
Anonymous
  • 53 Answers
  • Posted on Sep 05, 2009
SOURCE: My PC doesn't recognize my LG Xenon
get a memory card adapter you can get one for reasonably cheap at walmart and hook that up to your computer don't use a cable that will not access files on your memory card
How do I download pictures from my lg cu920 cell phone. Do I need the software for it.
You just need the proper USB cable to connect [your cell phone] to the computer and make sure (if necessary) that your phone's Connection is set to Mass Storage.
2answers
I want to download pictures from lg cu920 mobilephone to my computer dell-mini-inspiron.how can it be possible? I have usb cable.
I have this PC suite, from my wife's KF750 phone, uploaded. I don't know whether it is device specific or not, though. Give it a try, if you really want.
Hope it works for you too.
Regards, Carlos
1helpful
I want to get pictures off my phone onto my PC
since the drivers for your phone are not reconized it is giving that error
install the pc suite for lg..
tell me incase any issue
1helpful
3answers
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Can u pls help me how to start USB like i need to download songs whch i cnt pls
You first need find your installation disk that usually come with your phone so your computer will be able to properly read your device you are trying to connect, after connect your USB to your cell and then to your computer. It should read..if not, Try 1)Phone settings from off your cell..2)Connectivity..3)USB connection mode..4)Mass storage, by doing this it will set your cell in Mass storage mode allowing you to add Music, Pictures, Video etc. onto your cell memory. (You must insert a memory card to do this)
Cant get usb data cable to work
As long as you have a memory card installed in your phone, you should have no problem. Use a micro SD card of no larger than 4 GB. Attach the cable to your phone and computer via an available usb port. Your pc will then recognize your memory card as a mass storage device, and you cn drag and drop your files to and from the computer.Make sure your phone usb connection is set to mass storage.
Can't get my computer to "see" my LG Vu.
Assuming that you have a memory card in your phone- up to 4 GB, your computer should recognize the memory card as an external drive or storage device. Go to My Computer, and you should see an icon for this under your Hard Drive, CDRom, etc. Click on this icon- usually called Drive E, and drag and drop your files from there.
Move all pictures from lg vu cu920 to pc with data cable
You can move all the photos on your memeory card to your pc using a data cable. Your memory card will be detected as an external mass storage device, and you simply drag and drop them onto your computer. Any photos that are installed by your cellular service provider are locked into your phones memeory and connot be moved however.
2helpful
Unable to sync music to LG Vu Cu920
is your phone set to music sync mode,mass storage,ordata service. go to settings connections, usbconnection mode.
2helpful
How can i download pictures on my SGH-G800 to my computer?
The quickest way to do this is to put your phone into Mass Storage Mode then connect it via the USB cable to your computer. Your phone shows up as a USB Mass Storage Device and you can select the folders you want to download your pictures from.
To set your phone to Mass Storage Mode, do the following:
- Go to the main menu
- Select Settings
- Then Select Phone Settings
- Choose PC Connections from the menu
- And then click on Mass Storage.
When you connect the USB cable to your computer, your phone will show up as a USB Storage device and you can just copy and past files to it like you would a USB Thumb drive. If you select the Samsung PC Studio option...your file transfers will take ALL DAY. Just use Mass Storage mode. Good luck.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
