SOURCE: Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
SOURCE: Privacy
What you are experiencing is loss of programming. Is this fixed? Could be the batteries need replacing....
SOURCE: How to change Auto attendent Dial O to ring at multiple ext
First you will need to add extensions to a group X in #502
When you login to administrative mailbox you will change you operator extension to 7X. Phones in the group will ring
SOURCE: A phone line keeps ringing but no one is there.
No, could be a problem with the phone line....
SOURCE: I need to set the
Partner ACS systems come with Centralized programming instructions. Most of them starting with Feature 00 Left Intercom twice and Right Intercom. When you dial an extension, the lights will be solid or blink according to how it's programmed and you press each button to turn on or off or delay ringing.
Your system administrator should have a book.
Carl
