Only one of my UST-MS30 computer speakers is working...the right one is dead
Hi there!, I have read the manual for your system,..and maybe I can offer some solutions....Firstly, I am a musician and have experience with a lot of musical and studio equipment....some may seem simple, but it can bug you for hours or even days.
You must follow some simple troubleshooting steps,...to cancel out the possibilities.
Firstly, turn off your system, and disconnect it from the source,....I am guessing it is a PC.
Disconnect ALL connections and then set them up again with the power off. When all speakers and power supply is re-connected, turn on again. Run a speaker check, your system or PC should be able to help you with this. If the speaker is still not working, next, swap the right and left speaker outputs. If the speaker works, then the problem is NOT the speaker ok. If the speaker still does not work, then it is a bad speaker or bad lead to the speaker understand!?
