Configuration
shared by 3 users
posted by Kuglen on Aug 09, 2008
I have one of these, but i can't find a way to configure it. The manual tells me to enter 192.168.0.50 in my browser, but it doesn't load.
Please help!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on Nov 30, 2008
abrir puertos de emule
Posted by Guest on Sep 29, 2008
how do i know th ip off the acces point to lod in it
Best Solution
posted on Aug 09, 2008
Helpful (85)
Silverblade
Rank:Wiz Wiz
Rating: 80%, 62 votes
The best way to set this access point is to connect your computer directly to the device via Ethernet, disble the wireless adapter temporarily on the computer. Since this is just an access point and not a wireless router, it is not capable of providing your computer with an IP address because it has no DHCP functionality.
The IP address you mentioned is the deafault IP address of the access point, there is a posibility that the default IP has been change.
Do a reset on the access point then assign an IP address manually on your computer(i.e 192.168.1.x x- bein any number from 1 to 254 except 50)
Access the AP using Internet Explorer or Firefox, type http://192.168.1.50 on the address bar it should prompt you for a username and password(check you documentation for the default username and password for the access point)
Rating Locked! (?) Kuglen has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on configuration:
I don't want to Accept this solution
Solution #2
posted on Oct 16, 2008
Not Rated (0)
asmaos
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
iam use d-lik dwl-2100ap i can't reset the configration like ip when i press reset botton no any thing change
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Aug 30, 2008
Not Rated (0)
apeerystar
Rating: 0%, 0 votes
One of the problems with setting up any of these access points or routers is to understand the concept for connection.
First of all, your will need to go into the properties of the local network connection and open the TCIP protocal and change the ip configuration from the auto to a set ip address. Use 192.168.0.5 or anything between 1-256 except 50. then set your submask to 255.255.255.0 which will automatically load when you access that field. Then click OK to complete this setup. If you are lost in what I am saying by now, you may not be able to understand what is happening and need to get someone who understands this help you.
Once you have setup your local network adapter then you can plug it into you Dlink AP and open up you browser. Put the IP 192.168.0.50 into your URL file and hit enter and you should get the First screen for the setup of the unit, it will ask for a username - put in admin, leave the password blank and hit Okay to continue and then do your setup per your manual and the confiuration you desire.
Hope this will help and it does work.
Andre' Peery
Thank You!
Can you Help with these Wireless Access Points problems?
how to remove a input lock code of a china orion mobile
I bought a new Epson SX405 wifi printer with an Edimax...
does the ip port affect the wireless connection?
Reason code=1 I have a point to multi-point solution with...
D-Link AirPlus Xtreme G DWL-2100AP...
two dwl2100, one as ap, one as repeater,(ant 14dbi)...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Computers & Laptops
(412) 715-4340
We will fix all d-link or linklsys wireless...
ATCS Incorporated
(888) 430-9744
Computer Repair Over The...
OverNetUSA
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
