Ok a very very old DT , desk top, ive done this vast times, back long long ago... 17 years old, you use this old of hardware why?
we dont use XP in uSA its VIRUS magnet. horred
and no updates, now, means will get worse each day forward in time. endless...
has built in, SCSI chip. l Ultra160 SCSI and Ultra ATA/100
that ATA means PATA port, not SATA back then.
my wild guess now is that someone put an a new SATA card in the PCI slot, (ive done so vast times)
The BIOS in your machine will never support that.
that means you can not boot to PCI SATA. for sure.b
but wait, the better SATA card works just like a new Adaptec
ultra160 card that if love.
the new SATA card has what is called a BIOS extension ROM on said card, and a new HOT key to access it.
some are CONTROL +A but each maker of said card ,does as he pleases, so READ THERE MANUAL.
you set it to boot o STAT port and it does if port 0 is bootable drive. SATA.
here ill take you now to newegg.com and show you hardware that works.
if you showed a photo of your CARD and # id have answered, 10x better. !!!!!
i cant shop for you, nor pick SATA 1 ,2 or 3 for you.
but here
https://www.newegg.com/Product/Product.aspx?Item=9SIAC0F5KW5808&cm_re=sata_card-_-9SIAC0F5KW5808-_-Product
the big trick here is making sure you relic MOBO
supports the current levels of PCI>
like above
32-bit / 66MHz PCI interface compliant to PCI Rev 2.3
(Backward-compatible with PCI 33
https://www.promise.com/media_bank/Download%20Bank/Datasheet/FT_TX2300_DS091406.pdf
Control +F (see page 11)
https://www.promise.com/media_bank/Download%20Bank/Manual/FastTrak_TX_Series_User_v3.2.pdf
warning, ive run in to big problems using very old relic
motor-boards that use the very old PCI signals and levels.
and will fail on some newers card
I warned you,
the above reads good. for that. (hope )
now my question why use such old hardware.
when goodwill has truck loads of 10year old pCs for $20
why, love of XEON?
id trash it.
find a use desktop with SATA ports, ALL DO now, or scrapped.
SOURCE: Ethernet Drivers for Compaq Evo for XP
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=998
This should work.
And just to add that your system specs are really old and you should think about upgrading. 128 mb ram upgradable to 2 gigs.
Integrated 4x agp graphics...you should be able to install a new agp graphics card.
Or you should buy a new computer if you dont know how to build your own which can be tricky and expensive if you cant reuse many parts.
SOURCE: Audio Is Out! Compaq Evo D5 Desktop PC
uninstall the audio drivwers first and then restart the system and let system search for the drivers automatically
SOURCE: I need LAN drivers for
For audio driver download you can use this link
There are four different types of LAN adapters installed on this machine model.
Broadcom NetExtreme Gigabit Drivers
Intel Gigabit Drivers
Intel PRO/1000 Drivers
and
3COM Drivers
This should solve your problems. Good Luck!
