SOURCE: central locking system stopped working
If the A6 layout for the modules is the same as my A4, the lock pump is in the rear corner of the car, on the passenger side. In the trunk, pull up the carpeting behind the passenger rear wheel, and tucked down in there is the pump assembly. They're known to go bad and it's a pretty likely cause for your problem, provided your fuses are not blown.
SOURCE: 99 Jeep Grand Cherokee Tailgate Lock
I don't think you need a wiring diagram.
Jeep had alot of problems with the lock accuator in the tailgate.
SOURCE: Sentry Key system won't let me start my Jeep Grand Cherokee
get a new key. you can easily bypass your alarm to ignition conection, worked for me!
SOURCE: my renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
