I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Vovo
d nga makita sa taskbar tapos shift+idodouble click sa taskbar paka tanga nmn ng nag post n2..
Double click on C:\Program Files\Faronics\Deep Freeze\Install C-0\_$Df\FrzState2k.exe. The icon should appear and Ctrl+Alt+Shift+F6 should work.
Just click ctrl+shift+alt+F6, the deepfreeze window will open in desktop.
hope this useful. regard riyan.
