You can watch the video below to see how to role the bag.
http://www.youtube.com/watch?v=AAsAX931l64
Try this video
http://www.youtube.com/watch?v=z3YqnP985...
Rolling Zip up sleeping bag.
Fold in half, lengthwise.
If applicable, fasten toggle and loop to ensure bag stays in folded position.
Start rolling snuggly from opposite end of ties, loops or straps (whichever applicable). Have ties lying directly on the ground.
After rolling bag completely, secure ties, loops or straps. If bag has Wrap 'N Roll feature, continue rolling into attached carrier, tie and transport.
Care and Cleaning of Coleman® Sleeping Bags
Proper care of your sleeping bag will keep it looking better and lasting longer. Follow these simple suggestions to care for your Coleman® sleeping bag during the years to come.
Dry Cleaning - Dry cleaning is NOT recommended.
Washing InstructionsUse only oversized commercial front loading washing machine with a rotating drum action - DO NOT use top loading agitator style machines.
Wash warm, rinse cold on gentle cycle using ¼ mild detergent.
Use a fabric softener in wash. (Do not use detergents with bleach.)
Tumble dry at low temperature in oversized commercial dryer.
Alternate method: hand wash in bathtub, follow instructions as in #2.
Bag must be thoroughly dry before being stored.
Storing
For longtime storage, it is not recommended to store sleeping bags in its stuff sack or carrier, since it can reduce the loft, or puffiness, of the bag over time.
I found you a great guide
that should be helpful - it is an 8-step how-to guide on rolling up sleeping
bags. Good luck!
http://www.wikihow.com/Roll-a-Sleeping-Bag
And if you are more of a visual learner, I also found a
great video tutorial - I know how frustrating it can be sometimes, I sympathize
with you.
There
are three basic types of sleeping bags:
Rectangle - the sleeping bag we were probably
all raised with. This is a basic rectangle and rolls up to about the size
of a small car. Only use these in the summer, and only if you can drive
directly to your camping site. The upside of these bags is they provide
lots of room for your feet, and can be zipped together for Mom and Pop sleeping.
They are often thick too, which will help to cushion you from the hard
ground.
Barrel - The barrel sleeping bag is slightly
oval shaped, which provides more body warmth. It is roomier than a mummy
bag, but does not usually come with a hood like the mummy.
Mummy - The mummy sleeping bag is what you need
when camping in cold weather. It tapers as it goes down toward your feet,
providing a close fit and therefore trapping body heat. It has a hood
that wraps around your head and neck, keeping your body heat inside the
bag. The mummy has draft tubes, which are filled fabric strips sewn along
the zipper, keeping your bag draft free. The downside is only for those
who have claustrophobia and may feel trapped inside this tighter fitting bag.
Boy Scout uses a malleable mummy sleeping bag, rated
at 0 degrees. He is toasty warm at the freeze-o-ree, and can open the bag
in the summer to cool off. This large bag easily scrunches in to a small
stuff sack which is carried on his backpack. The $140 was well worth the
quality, warmth and compatibility.
