Normally there are 2 different ways to check ink level on any HP printer
First one is :
IF your printer is HP Officejet 6500 Wireless AIO,
Press Setup button ( ranch like symbol ) on printer front panel
Use Arrow key ( left or right arrow ) till you find Tools option - Press OK
User Arrow key to find Ink Level or Ink Gauge - Press OK.
It should display the ink level.
If it does not display ink level through this method, it could be for many reasons like printer is not aligned or one of the cartridge is not recognized etc.
2nd method is from PC
Open HP Solution Center
Click on Settings
Click on Printer tool box
Click on Ink level
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts,
