Dishwashers Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motar just hums wont do anything but hum - Dishwashers
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on Apr 19, 2011
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1670490
Points
10301
If the motor just hums and there is nothing stopping the motor from spinning then it is smoked and will need to be replaced. Wish I had a more happier answer for you but I don't.
Regards, Tony
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Fills with water and then stops makes a humming sound ,then stops all togther wont do aything spin or drain
sounds like an induction motor. start winding or start capacitor not starting to turn motor, This will make motor hum. Do not know m/c in qestion. Switch on and as soon as pos try to turn motor careful not to use hands or anything that can injure yourself with if it starts to spin.
NOT RECEIVING ANYTHING BUT STATIC HUMS WHEN I KEY IT UP AND WONT CALIBRATE OR TX BUT RECEIVES WEATHER BAND PERFECTLY
hello from what you are saying it sounds like not enough power have you connected this to power supply with output voltage 13.8volts ,,yes well if you have the problem is with the voltage regulator you will need to have this replaced this would cause the hum unless you were using a battery with charger connected this would cause a hum aswell goodluck
3answers
Humming noise when turned on
The montherboard doesn't have anything that would make a humming noise. In all likelyhood it's the fan that sits on top of teh processor. It could be normal, but might need to be replaced or cleaned.
7helpful
2answers
Everytime i use my frigidaire gas stove burner, it will make a loud humming noise. when i turn on a 2nd burner the humming sound will go away..is this normal for this brand?
SOUNDS LIKE YOU HAVE A REGULATOR PROBLEM. IT WONT HURT ANYTHING ITS JUST ANNOYING. OR YOU CAN REPLACE THE REGULATOR
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
6helpful
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 • Dryers
1helpful
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Have an LG dehimidifier which seems to have stop working
Could be a failed compressor start relay. They are replaceable. Get one at an appliance parts store for your model or a generic one. Make sure you are unplugged before changing.
2answers
Dishwasher wont go into cycle mode and hums
No model and brand name .
the way you mention look like the main motor jammed and making the humming noise click out on overload then the humming noise stop and after a while it will humming again and continue like that until you switch off the machine. If the dishwasher is old I would recommand you buy a new one instead of changing the motor.
God Bless have a nice day Dickson
Jun 30, 2009 • Dishwashers
1helpful
Background "hum" in R speaker
Yea try plugging it into another wall socket, if it's still humming could be a damaged transformer. or bad capacitor.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
