NEC Dterm DTP 16D-1 Corded Phone Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at the extension, leaving the extension to ring only when receiveing any internal intercom calls, or when any incoming calls are transferred to that extension by the receptionist /attendent or if any calls come in on the Direct Line of that extension; just NOT to ring as the receptionist phone rings on ALL incoming calls to the business.
  • 2 more comments
  • marsha436 Apr 21, 2011
    I need the phone to continue to ring when its direct line is being used to contact him. I also need the ringer to work for any interoffice calls coming to him. I just need to know how to program or unprogram that particular extension to NOT ring when there is an incoming call for the businsess that always rings at the receptionist desk, but we have this one other extension enabled to ring as a backup person to answer the phone in the event the receptionist cannot do so. We no longer want this particular extension to be the back up person for company's incoming calls and need to DE-program it as back up.
    My phone is a model DTH-16D-2. The posting above stated
    Problem with NEC Dterm DTP 16D-1 Corded Phone.
    I received a reply from someone but it was not sufficient to fix my problem. Please help.
    I posted a response to you, then noticed a "Reply to..." button lower on the page. I hope you received my post and can help.
    marsha436
    My problem is a programming issue. Not a volume control setting on the phone. I need to keep the phone in its current working conditon, to ring when called on an internal line, to ring when called on the direct line to that office, etc. I just do not want it programmed as is the main attendant phone, to ring on ALL INCOMING calls to the business on our main phone number.
Anonymous
Level 3:
Guru:
  • Master 825 Answers
  • Posted on Apr 22, 2011
Anonymous
Master
Level 3:
Guru:
Answers
825
Questions
0
Helped
238987
Points
2508
You can change these settings by logging into the phone's ip address from the computer that is connected to the same network.
You can also try to enter into the menu of the phone directly from the interface and look for these settings..
electronic & computer repair& servicre
Level 3:
  • NEC Master 12,061 Answers
  • Posted on Apr 19, 2011
NEC Master
Level 3:
Answers
12061
Questions
0
Helped
4006107
Points
36390
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
1helpful
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
How to reset for mailbox choices
Hi Debbie - I also have the DTerm80 Series - there is one phone in your group that acts like a main phone. If you find that phone and follow these prompts you would be able to set your company vm to include your extensions:
To set morning message:
Message
72
INSTR
001
Record
To set evening message:
Message
72
INSTR
002
Record
At Receptionist phone- shows a solid green light on rights side of a specific extension- at that extention it is a green flashing light, but no message- looking to see how we get rid of the green light at...
On the attendant phone:
1. Press the Message key on the Attendant Add-On Console.
2. Press the DSS key on the Attendant Add-On Console that is associated with the station where Message Waiting is to be canceled.
How do I set the phone to night ring? I used to have the information, and I believe it was *86, but I cannot find it now.
From the attendant console or receptionist phone (100/101 or 10/11):Dial Feature, 80, Feature.
11helpful
2answers
NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
RECALLING PHONE NUMBERS
while talking on that line press line key again.
1helpful
Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
2helpful
2answers
Change the time on dth 16D-1
If this is an NEC Elite system, you must be on a phone with "attendant" features. By default they are on ports 1 and 2. Try and find an ext 10, 100, 1000 or something like that. Pressing Feature - 4 tells you what port the phone is.
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
