This is not a battery problem. It likely levels to the back corner, then to the front corner then roughly back to the middle and spins at about 150 rpm and the lights on the front blink.
There are a couple things that can cause this. the most common is the the compensator cant find the laser. 5 screws hold the main housing on to the base. Remove the housing and inspect. if the internals are coated in oil, then the unit is done. The replacement part is too expensive.
If the inside is dry, there is a small circuit board on the left side of the metal compensator frame. Resolder the pins in the board, and the connector going to the side board, located on the main board. about 30% of the time, this will get the laser running again. If not, the laser diode is likely dead, and it's not repairable.
SOURCE: i have an rt-5250-1 self
If the directions are not real clear as you say, then you should call the manufacturer to get tech support. I will send you a link to there site and phone #.
http://www.toolauthority.com/RoboToolz-RT-5250-2XPK.html
Good Luck!
Jim
