Sport & Outdoor - Others Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1999 ezgo txt golf cart and want to know what type and size 12 volt battery to install?
Anonymous
Level 2:
  • Expert 274 Answers
  • Posted on Apr 19, 2011
Anonymous
Expert
Level 2:
Answers
274
Questions
Helped
70573
Points
862
You need 4 12v deep cycle batteries. If you have an old one use that to get the proper dimentions. They are usually the same size that is used in a small car. You can get those at any auto parts store.
Have a good day!
1helpful
Ezgo txt golf cart hesitates and looses power, yet shows full battery charge.
loose power connection or bad ground somewhere. get a little metal wire brush (or several of them), disconnect battery, and disconnect ground and power wires (keeping track of them), and start brushing them, then re-attach and test
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
https://www.google.com/search?q=1999+TXT+EZGO+golf+cart+controller&oq=1999+TXT+EZGO+golf+cart+controller&aqs=chrome..69i57.1143j0j4&sourceid=chrome&ie=UTF-8
Aug 02, 2017 • Golf
Wheres the ground go on healights on a ezgo 3 wheeler
Never had a ezgo 3 wheeler to work on before but sounds interesting. If this is an electric cart then wire ground to a negative battery that gives 12 volts from where positive is connected. If gas cart wire to frame or neg post of battery.
Mar 28, 2017 • Golf
1helpful
I have a ezgo 36 it's got power but runs slow, batteries are full
Does your controller have a 6 pin connector on the top? If it does then only 4 pins are wired. Pins 1 and 2 are the throttle, pin 3 is reverse and pin 4 activates the controller.
First I would check the batteries under load. then check voltage from main negative battery post to pins 3 and 4. Should get approx. 15 volts going to the ITS throttle and other pin should get 5 volts at full throttle. If you get no voltage at either pin then probably a bad controller. Go to buggiesgonewild.com and search for wiring diagrams, they have a few for download.
I need a service manual for an EzGO TXT
Service manuals are sold by EZGO but expensive. You might download some wiring diagrams from fsip.biz and buggiesgonewild.com.
Top Sport & Outdoor - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
